I have a really weird problem with the Arduino MKR 1300 and the use of the RTCzero library. Simply put when I use both of them the data does not get sent and I have no idea why. The alarms when not trying to send data work normally and the modem.print(msg) also works normally when I am not using the RTC library.
The code looks like this:
#include <EmonLib.h>
#include <RTCZero.h>
#include <MKRWAN.h>
EnergyMonitor emon1;
EnergyMonitor emon2;
EnergyMonitor emon3;
RTCZero rtc;
LoRaModem modem;
String appEui = "1234567891011121";
String appKey = "ffffffffffffffffffffffffffffffff";
/* INITIAL_TIME */
const byte seconds = 0;
const byte minutes = 0;
const byte hours = 0;
const byte day = 17;
const byte month = 12;
const byte year = 18;
byte second_alarm = 0;
byte minute_alarm = 0;
byte hour_alarm = 0;
byte INTERVAL = 60;
int SEND_LOOP = 2;
int totalKW;
int time_running = 0;
void setup()
  Serial.begin(115200);
  if (!modem.begin(EU868)) {
    Serial.println("Failed to start module");
    while (1) {}
  Serial.print("Your module version is: ");
  Serial.println(modem.version());
  Serial.print("Your device EUI is: ");
  Serial.println(modem.deviceEUI());
  Serial.println("Connecting");
  int connected = modem.joinOTAA(appEui, appKey);
  if (!connected) {
    Serial.println("Something went wrong; are you indoor? Move near a window and retry");
    while (1) {}
  Serial.println("Connected");
  // Set poll interval to 60 secs.
  modem.minPollInterval(60);
  analogReadResolution(9);
  emon1.current(1, 53);
  emon2.current(2, 53);
  emon3.current(3, 53);
  time_running = 0;
  rtc.begin(); // initialize RTC
  rtc.setAlarmTime(hour_alarm, minute_alarm, second_alarm);
  rtc.enableAlarm(rtc.MATCH_HHMMSS);
  rtc.attachInterrupt(ISR);
  // Set the time
  rtc.setHours(hours);
  rtc.setMinutes(minutes);
  rtc.setSeconds(seconds);
  // Set the date
  rtc.setDay(day);
  rtc.setMonth(month);
  rtc.setYear(year);
void loop()
void ISR() {
  int totalWatt = 0;
  unsigned long delay_send = 0;
  int sending = 0;
  double Irms1 = emon1.calcIrms(600);
  if (Irms1 < 0.3) Irms1 = 0;
  double Watt1 = Irms1 * 230;
  double Irms2 = emon2.calcIrms(600);
  if (Irms2 < 0.3) Irms2 = 0;
  double Watt2 = Irms2 * 230;
  double Irms3 = emon3.calcIrms(600);
  if (Irms3 < 0.3) Irms3 = 0;
  double Watt3 = Irms3 * 230;
  totalWatt = Watt1 + Watt2 + Watt3;
  totalKW = totalKW + totalWatt / 1000;
  Serial.println(time_running);
  sendDataChecker();
  setAlarm();
  time_running = time_running + 1;
void sendDataChecker() {
  if (time_running == SEND_LOOP) {
    double IrmsTotal = Irms1 + Irms2 + Irms3;
    String msg = "{\"id\":\"avac_aud1\",\"kW\":" + String(totalKW) + ", \"current\":" + String(IrmsTotal) + "}";
    int err;
    Serial.println("Ready to Send");
    modem.beginPacket();
    modem.print(msg);
    err = modem.endPacket(true);
    Serial.println("Sent1");
    if (err > 0) {
      //message sent correctly
      Serial.println("Sent");
      time_running = 0;
      totalKW = 0;
    } else {
      Serial.println("ERR");
      time_running = 0;
void setAlarm() {
  second_alarm += INTERVAL;
  if (second_alarm >= 60) {
    minute_alarm++;
    second_alarm = 0;
  if (minute_alarm >= 60) {
    hour_alarm++;
    minute_alarm = 0;
  if (hour_alarm >= 24) {
    hour_alarm = 0;
And here's the output:
Connected
18:13:33.158 -> Ready to Send
Doesn't go beyond that and the data doesn't get sent. Also notice how some serials are missing, I also have no idea why, and I double checked the baud rate.
Bence Kaulics
  • 7,843
  • 42
  • 90
BryceSoker
  • 171
