I'm having trouble installing Android Things on an SD card. The card itself seems fine, it's recognised by my Macbook Pro. I'm using the same command i used for the last pi I set up.
Below is the command and the response I'm getting back.
I'm pretty new to Android Things but this command worked like a charm last time and nothing has changed AFAIK so no idea where to go from here.
Jamies-MBP:ic-self-help jampez77$ sudo ~/Downloads/android-things-setup-utility/android-things-setup-utility-macos
Password:
sudo: /Users/jampez77/Downloads/android-things-setup-utility/android-things-setup-utility-macos: command not found
Helmar
  • 8,450
  • 36
  • 84
jampez77
  • 361
The error implies that the file you are trying to run (/Users/jampez77/Downloads/android-things-setup-utility/android-things-setup-utility-macos) is just not where you've said it is.
Rather than trying to run it from a long path, which introduces more chance of a typo, try running it from the directory e.g.
cd ~/Downloads/android-things-setup-utility/
sudo ./android-things-setup-utility-macos
Also check that directory is still there and that actual command has the execute bit set.
hardillb
  • 12,813
  • 34
