I think, node.error does not halt the flow in all cases. My aim is to catch errors, save the payload and stop the flow.
Please refer the observations and experiments below.
Observation
Function node - Neither error is caught nor does the flow halt.
JSON node - Error can be caught and flow halts.
Postgres node - Error is not caught but the flow halts.
Experiments
All of the experiments below have Catch nodes to handle errors from all nodes in the flow.
Function node
I added a function node that is wired to an Inject node. The output of this node is a database INSERT query, wired to a Postgres node. In the function node, right at the top, I added this node.error('Test error'). While the error can be seen in the console, I can see row inserted into the database. I am not able to catch it either.
JSON node
I wired a JSON node to a MQTT Input node to transform the JSON string payload to a JSON object. This object is passed to a function that generates a INSERT query statement and is wired to a Postgres node. For testing, I passed a malformed JSON document which causes an error in the JSON node. I can catch it and the flow stops too.
Postgres node
With good JSON document, no node.error() statement in function node, the Postgres node inserts successfully. For testing, I created a well-formed JSON document that will raise a duplicate on insert message. In this case, I can see the error message in console. But, I can't catch it.
Note that, the Postgres node does raise a node.error().
Query execution
Refer this.
try {
for (let i=0; i < queries.length; ++i) {
const { query, params = {}, output = false } = queries[i];
const result = await client.query(query, params);
if (output && node.output) {
outMsg.payload = outMsg.payload.concat(result.rows);
if (node.output) {
node.send(outMsg);
} catch(e) {
handleError(e, msg);
} finally {
client.release();
Error handling
Refer this.
var handleError = (err, msg) => {
node.error(err);
console.log(err);
console.log(msg.payload);
Questions
How can I be sure that any node that raises a node.error() will definitely be caught by a Catch node? Or, in which circumstances, will the Catch node not catch a node.error()?
