This is my code and on the bottom is the error I keep getting.
import configparser
from time import localtime, strftime
import json
import paho.mqtt.client as mqtt
config = configparser.ConfigParser()
config.read('/home/pi/bin/py.conf') # Broker connection config.
requestTopic = 'services/timeservice/request/+' # Request comes in
here. Note wildcard.
responseTopic = 'services/timeservice/response/' # Response goes
here. Request ID will be appended later
def onConnect(client, userdata, flags, rc):
print("Connected with result code " + str(rc))
def onMessage(client, userdata, message):
requestTopic = message.topic
requestID = requestTopic.split('/')[3] # obtain requestID as last
field from the topic
print("Received a time request on topic " + requestTopic + ".")
lTime = strftime('%H:%M:%S', localtime())
client.publish((responseTopic + requestID), payload=lTime, qos=0,
retain=False)
def onDisconnect(client, userdata, message):
print("Disconnected from the broker.")
Create MQTT client instance
mqttc = mqtt.Client(client_id='raspberrypi', clean_session=True)
mqttc.on_connect = onConnect
mqttc.on_message = onMessage
mqttc.on_disconnect = onDisconnect
And after I try to connect to a broker:
mqttc.username_pw_set(config['MQTT']['userMQTT'], password=config['MQTT']['passwdMQTT'])
mqttc.connect(config['MQTT']['hostMQTT'], port=int(config['MQTT']['portMQTT']), keepalive=60, bind_address="")
I get the fallowing error:
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/usr/lib/python3.5/configparser.py", line 956, in __getitem__
raise KeyError(key)
KeyError: 'MQTT'
Does anybody know how to fix this error while trying to connect to a broker?
