11
I'm working on an IoT project that involves thousands of MQTT clients that are connected to a broker (mosquitto) via 4G/WiFi router/modem. Less than 10 clients are connected to the same router, and the routers come from different places (different cities).
Right now we have very few clients and they are always-connected to the broker. I know from this discussion that there will be no problems even when they will grow up to 1000+ units.
My question is about the traffic load on the 4G connection. The end-user is afraid about data consumption with all those "channels" opened and not used. As far as I understand when there is no activity only the keep-alive packets are sent, though I cannot find this information for sure in the MQTT documentation.
Can I assume the traffic when no packets are published is negligible?
Mark
  • 747
  • 13
The MQTT spec lists the details of the PINGREQ and PINGRESP packets which make up the keep-alive transaction.
Each is just 2 bytes in size so a full keep-alive event uses 4 bytes in total. Since you can control how often keep-alive packets are sent for each client based on how quickly you need to know that connection has dropped you have full control how much data is used when no messages are actually being published.
If you want to reduce the data load even more you could have a separate broker running before the 4G router that the 10 devices connect to which is then bridged to the central broker. This would reduce the number of keep-alive packets to 1 per 4G router rather than 1 per client. This has the advantage that the 10 local devices can continue to pass messages between each other if the link goes down and you can use retained messages/Last Will and Testement messages to track when individual clients go down.
hardillb
  • 12,813
  • 34
