I am trying to connect a IoT node to a IBM IoT server via MQTT/GSM. I am using a Sim800L GSM module, and a serial USB device to send the commands to module from my computer. Later on, I will use the commands on Arduino to register my device. I'm sending following command to GSM Module:
AT+CIPSTART="TCP","[my-org-id].messaging.internetofthings.ibmcloud.com","my-port"
And I get the following output
CONNECT OK
But for connecting my device to BlueMix, I need to submit username and password. There isn't any documentation that I find on doing that, so i tried that:
AT+CIPSEND
>usernamepassword
SEND OK
And after a few seconds after sending that:
CONNECTION CLOSED
So I think that this is not a valid way to submitting user and password. But I couldn't find any documentation about authentication on MQTT with GSM.
codemonkey
  • 181
I've found this library useful to solve issues with authentication. If you encountered same issues on GSM modules with Arduino, it may help you as well:
https://github.com/elementzonline/SIM800_MQTT
codemonkey
  • 181
