We are robotics based company.We started our work in Industrial IoT, as we are in early stage.The problem we are facing is remote connectivity between server client.
The server which has static IP is connected to main office. The client is connected to a robot with m2m 3G router via Ethernet access. Both the connections are at different network.I want to know the best possible solution.
Helmar
  • 8,450
  • 36
  • 84
Rohan
  • 17
I work as a solution engineer at Talend, and I’ve worked on IOT / SCADA integration. While you’ve not supplied much detail, to me this sounds like a data integration problem.
If that’s the right problem, then your choices are to build or buy an IOT platform solution. An IOT platform covers ingest from various IOT sources, processing, analytics, and publish to various target systems. https://www.talend.com/blog/2017/04/11/simplify-iot-platform-talend/
Here’s more on how Talend’s Data Fabric works for IOT...
Talend brings it all together in an end-to-end integration platform that combines IoT connectivity (AMQP, MQTT); high-speed, reliable messaging (Apache Kafka, Amazon Kinesis, Talend ESB); and high-speed big data processing (Apache Spark).
https://www.talend.com/solutions/information-technology/internet-of-things-real-time/
