If anybody has experience the Multitech mDot and Conduit modules to set up a LoRa network I could use their help.
I’ve set up a LoRa network consisting of an mDot node (plugged into a Multitech developer board, programmed using mebd compiled code) which connects to a Conduit gateway that forwards the packets to LORIOT network server.
The problem I’m having is that the mDot will for a short while connect perfectly, sending data to the gateway which is forwarded and recieved on the network server, but then unexpectedly will fail to connect to the Conduit with
failed to join network -4:Join Error
and will not connect for long periods of time if at all again and will do the same
Does anybody know what could be causing this?
