I am trying to pull a few bytes per second from a microchip board attached to a temperature sensor and a photodiode, using Windows 10 IoT on a Dragonboard 410c. It seems like there's either interference when I attempt to read from more than one GPIO at a time. How can I get input from these GPIOs without messing up my clock signal?
namespace DashWall
    public sealed partial class MainPage : Page
        private const int CLOCK_PIN = 12;
        private const int TEMP_PIN = 34;
        private const int PHOTO_PIN = 33;
        private const int START_PIN = 36;
        private GpioPin clockPin;
        private GpioPinValue clockPinValue;
        private GpioPin tempPin;
        private GpioPinValue tempPinValue;
        private GpioPin photoPin;
        private GpioPinValue photoPinValue;
        private GpioPin startPin;
        private GpioPinValue startPinValue;
        private DispatcherTimer timer;
        private GpioController gpio;
        public MainPage()
            InitializeComponent();
            timer = new DispatcherTimer();
            timer.Interval = TimeSpan.FromMilliseconds(10);
            timer.Tick += Timer_Tick;
            InitGpio();
            timer.Start();
        private void InitGpio()
            gpio = GpioController.GetDefault();
            clockPin = gpio.OpenPin(CLOCK_PIN);
            tempPin = gpio.OpenPin(TEMP_PIN);
            photoPin = gpio.OpenPin(PHOTO_PIN);
            startPin = gpio.OpenPin(START_PIN);
            clockPin.SetDriveMode(GpioPinDriveMode.InputPullUp);
            tempPin.SetDriveMode(GpioPinDriveMode.InputPullUp);
            photoPin.SetDriveMode(GpioPinDriveMode.InputPullUp);
            startPin.SetDriveMode(GpioPinDriveMode.InputPullUp);
        bool isReading = false;
        bool bitRead = false;
        uint curPhoto;
        uint curTemp;
        uint bitCount = 0;
        bool start;
        bool clock;
        bool photo;
        bool temp;
        private void Timer_Tick(object sender, object e)
            handleInput();
            Time.Text = "" + clock;
            Temp.Text = "" + temp;
            if (start && clock && !isReading)
                Temp.Text = "" + start;
                isReading = true;
                curPhoto = 0;
                curTemp = 0;
            if (isReading)
                if (clock && !bitRead)
                    ReadBit();
                    bitRead = true;
                if (!clock)
                    bitRead = false;
        private void ReadBit()
            uint photoBit = 0;
            uint tempBit = 0;
            if (photo) { photoBit = 1; }
            if (temp) { tempBit = 1; }
            curPhoto = curPhoto << 1;
            curPhoto = curPhoto + photoBit;
            curTemp = curTemp << 1;
            curTemp = curTemp + tempBit;
            bitCount++;
            if (bitCount >= 8)
                isReading = false;
                bitCount = 0;
                //Time.Text = "" + Convert.ToString(curPhoto, 2);
                //Temp.Text = "" + curTemp;
        private void handleInput()
            clockPinValue = clockPin.Read();
            clock = clockPinValue == GpioPinValue.High;
            startPinValue = startPin.Read();
            start = startPinValue == GpioPinValue.High;
            photoPinValue = photoPin.Read();
            photo = photoPinValue == GpioPinValue.High;
            tempPinValue = tempPin.Read();
            temp = tempPinValue == GpioPinValue.High;
anonymous2
  • 4,902
  • 22
  • 49
Somnacin7
  • 79
Turns out that the ground cable between the two microcontrollers had been dislodged. Putting that back in place fixed my problem.
Somnacin7
  • 79
