We use the CSRA64215 to stream audio by Bluetooth to our audio hardware. Now this chip has a Kalimba DSP integrated. Is it possible to control the DSP's EQ settings by Bluetooth for example via AVRCP or similar? We would like to create an android app to achieve this. I am very new to this kind of engineering, can someone give me a hint?
Maybe you can map the simple events that are controllable by java bluetooth like play or pause etc. via avrcp to the eq settings. I will do some research into that direction and post the results. Thanks for your help.
