Objective:
Finding out about terminology/ specification to help me source economically priced hardware for DIY installation. (My Google search for wireless light switching produces wall switches operatable by apps but physically wired to the light circuit, like a mechanical switch).
Situation:
I have a group of led lights, less than 100 W total. I want to operate this group through a wireless signal from a wall switch and/or touch panel. I prefer to use dumb globes connected to a device which receives the operating instruction wireless from a wall switch and /or touch panel to control the dumb globe.
Question:
What hardware devices (Zigbee compatible) are required to receive the wireless signal and operate the circuit. See image below: enter image description here (third layout is what I am looking for)
a) for simple ‘on/off’ operation
b) for ‘on/off’ operation with ‘dimming’
c) What Zigbee compatible hardware device (instead of the conventional light switch) is required to generate the wireless signal for a), for b)?
Helmar
  • 8,450
  • 36
  • 84
Frits
  • 91
My first search for 'zigbee relay' came up with this survey. The devices shown here seem suitable for your application (at least many of them).
Dimmer/switch
Although they are often described as suitable for fitting behind a switch, you don't have to use them like that. For a switch function, you should look for one which requires a live and neutral connection (so the device can be powered without relying on a path through the lamp).
You can chose mechanical relay devices (in effect a remote switch), or electronic switches/dimmers. The electronic switches ought to be OK with an LED lamp, but the dimmer variants are more tricky - the design of a typical LED lamp means that it will not dim as expected. To achieve proper dimming, the lamps you use will need to regulate themselves, or you need a dimming power supply for a collection of low-voltage bulbs.
Sean Houlihane
  • 10,524
  • 26
  • 62
