11
I'm trying to control an ESP8266 using fauxmo. The programme compiles correctly, but when I run the Alexa app to find devices the ESP doesn't show up.
The ESP is definitely connected to my home network, and the programme is running (I've checked the serial output). Also other networked devices, like my Nest thermostat are showing up.
Any ideas as why it might not be showing up, greatly appreciated.
Here's the code on my wemos d1 mini
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include "fauxmoESP.h"
#define WIFI_SSID "..."
#define WIFI_PASS "..."
#define SERIAL_BAUDRATE                 115200
fauxmoESP fauxmo;
// Wifi
void wifiSetup() {
    // Set WIFI module to STA mode
    WiFi.mode(WIFI_STA);
    // Connect
    Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
    WiFi.begin(WIFI_SSID, WIFI_PASS);
    // Wait
    while (WiFi.status() != WL_CONNECTED) {
        Serial.print(".");
        delay(100);
    Serial.println();
    // Connected!
    Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
void callback(uint8_t device_id, const char * device_name, bool state) {
  Serial.print("Device "); Serial.print(device_name);
  Serial.print(" state: ");
  if (state) {
    Serial.println("ON");
  } else {
    Serial.println("OFF");
void setup() {
    // Init serial port and clean garbage
    Serial.begin(SERIAL_BAUDRATE);
    Serial.println("FauxMo demo sketch");
    Serial.println("After connection, ask Alexa/Echo to 'turn <devicename> on' or 'off'");
    // Wifi
    wifiSetup();
    // Fauxmo
    fauxmo.addDevice("relay");
    fauxmo.addDevice("pixels");
    fauxmo.onMessage(callback);
void loop() {
  fauxmo.handle();
Aurora0001
  • 18,520
  • 13
  • 55
  • 169
llewmihs
  • 161
So I found a solution to the problem.
I was originally going to connect the Fire TV stick Alexa to the esp. I bit the bullet and bought an Echo dot.
Problem solved.
Fauxmo in its current state doesn't seem to work with Fire TV.
llewmihs
  • 161
