I'm a web developer with 10 years' experience who just started looking into home automation.
I'm trying to figure out how to shorten the feedback loop while setting up my system. Currently, the best thing I got for updating is rebooting my Raspberry with sudo shutdown -r now.
I have tried calling the service homeassistant/reload_core_config, but nothing seems to happen, when I for example add an option to this input:
input_select:
  lullaby:
    options:
      - Rain
      - Babbling Brook
      - None
    initial: None
    icon: mdi:weather-rainy
You are suppose to be able to restart the system with this: sudo systemctl stop home-assistant@pi but I get this error: Failed to stop home-assistant@pi.service: Unit home-assistant@pi.service not loaded.
My ideal solution would be to trigger an update every time I upload a file over SSL to the server to the /.homeassistant folder.
Helmar
  • 8,450
  • 36
  • 84
Himmators
  • 169
Your command seems to be out of sync with the rest.
First it seems incomplete at the end at best and moreover why are you using stop to restart? Why not use restart.
sudo systemctl restart home-assistant@pi.service
Helmar
  • 8,450
  • 36
  • 84
Apperently this is the systemctl that was being used by raspbian
home-assistant@homeassistant.service
Himmators
  • 169
