12
I have a project where I would like to connect ~200 devices to a single AP.
Each of these devices will be offset in their communication so that there will only be approximately 10 devices relaying TCP packets to a server at any given time.
I would like all devices to stay connect to the server through open sockets at all time and just space out data sending in the way described above.
My first concern is the DTIM beacon messages that the AP will have to send to all of the devices. Will a reasonable priced (less than $500) router be capable of this?
Also if anyone else can think of additional problems that may occur that would be a huge help!
Aurora0001
  • 18,520
  • 13
  • 55
  • 169
Wolfgang_Horton
  • 221
From the sounds of what you're trying to do I think you'll be fine, and obviously the outcome will depend on the router you get. (I'm going to use Ubiquiti as an example)
According to a Ubiquiti employee the hard-coded limit on concurrent connections is set to 50 million:
https://community.ubnt.com/t5/EdgeMAX/Maximum-number-of-Connections-Sessions/m-p/1153434/highlight/true#M53514
However Ubiquiti does have their own (practical) recommendations:
http://dl.ubnt.com/UBNT-inter-ops-5g_2.pdf
http://dl.ubnt.com/UBNT_inter-ops-2.4g_2.pdf
As far as IoT is concerned, from my personal experience I used a $35 Ubiquiti Air Router for a Arduino Training session with 20 wifi modules connected to it.
For the exercise we all played a 20-player asteroids game where all 20 modules made a request every 20 milliseconds. So that would be about 1000 requests every second. The router performed perfectly with default settings.
for $35 I'd say it's worth a try
Adam Oakley
  • 219
