My neighbour has Lactose Intolerance which is a problem but a Nutritionist has advised that refraining from all dairy products for a while, then gradually returning to them, in measured amounts, can 're-balance' the system to tolerate dairy once again.
Is there documented evidence for this ?
I am also interested if intolerance is a feature only of 'free' lactose in food, as opposed to lactose that is associated with other components, such as 'bound' lactose which is intimately bound up with proteins.
Is there documented evidence for this also ?
My understanding is that primary (genetic) intolerance is not dependent on exposure (therefore, also, not affected by absence) and that secondary intolerance is reversible. But I would like to see confirmation of the combined effects.
Elimination of Lactose
Nigel J
  • 183
  • What has your research revealed so far? – Carey Gregory Oct 18 '21 at 21:34
  • @CareyGregory My understanding is that primary (genetic) intolerance is not dependent on exposure (therefore, also, not affected by absence) and that secondary intolerance is reversible. But I would like to see confirmation of the combined effects. – Nigel J Oct 18 '21 at 22:13
    It sounds like you've read a bit on this, which is good because this site requires questions to demonstrate some degree of prior research. Adding what you just wrote to your question along with a link or two to support it would vastly improve your question. Right now it has one close vote for lack of research, and I agree with that vote. – Carey Gregory Oct 18 '21 at 22:50
  • @CareyGregory Edited as per your suggestions. – Nigel J Oct 19 '21 at 03:48
According to this paper consumption helps not absence of lactose from diet
However, in lactase-deficient individuals, lactose feeding supports the growth of lactose-digesting bacteria in the colon, which enhances colonic lactose processing and possibly results in the reduction of intolerance symptoms.
I think the nutritionist is advising to refrain to get sure your neighbour doesn’t have FODMAPs intolerance, lactose intolerance tends to be part of a wider intolerance to poorly absorbed, fermentable oligo-, di-, monosaccharides and polyols (FODMAPs),and gradual returning is consistent with the argument I mentioned above.
Yes lactose in free and bound form can affect the symptoms accordingly
Consuming lactose with meals, especially fat (in milk or otherwise), slows gastric emptying, reducing the quantity of lactose exposure to the small intestine per unit time [60,61]. On the other hand foods like coffee or hot peppers may increase intestinal transit delivering lactose to the lower intestine and increasing symptoms. Lactose in fermented dairy products contain quantitatively less lactose volume for volume.
Samar Deep
  • 41
