I'm sensitive to salt and am considering doing a salt-free diet. Is it ok if I remove salt and seasonings from my diet and cooking altogether? Will the sodium content of natural foods like oats, milk, fruits and chicken be enough to sustain long-term health?
    Yanomamo Indians only get 0.06 grams of salt a day: http://circ.ahajournals.org/content/circulationaha/52/1/146.full.pdf https://academic.oup.com/ije/article/31/2/320/617698 – Count Iblis Jan 13 '18 at 20:09
  • Add up the salt and compare it to the recommended minimum. – paparazzo Jan 14 '18 at 11:53
    Low sodium diets have benefits but I'd ask your doctor before going too far below the recommended low-sodium restriction, since in some people an ultra low sodium diet can lead to hyponatremia, and you may want to ensure that you don't have a condition/medication that can predispose you to that. You can look up natural sodium content of foods and add it together to know what your daily intake actually is. – DoctorWhom Jan 15 '18 at 20:23
Assuming you are healthy, you will likely naturally regulate your sodium intake to appropriate levels. (Sodium is highly regulated by the renin-angiotensin-aldosterone system.) Too low and too high are both possible, and I would not attempt to manipulate sodium intake without without measuring or calculating current intake first.
If you are thirsty, you are either not getting enough water or eating too much salt. If you are craving salty foods, you're either drinking too much or not eating enough salt. Excessively high or low salt intake over long periods of time alters RAAS activity (otherwise serum sodium levels would be affected), so changes should be made gradually. Before making significant changes to your diet, you should consult your physician.
Decreasing salt intake had been recommended to decrease blood pressure. In "Why Should I Limit Sodium?" (pdf), The American Heart Association states:
Having less sodium in your diet may help you lower or avoid high blood pressure. People with high blood pressure are more likely to develop heart disease or have a stroke.
However, note that blood pressure is a proxy indicator with many causes that may have nothing to do with your overall health or how long you live. It is also possible for blood pressure to be too low (shock). No blood pressure = No life.
Many studies have not collected data on extremely low-levels of sodium intake, so no conclusion can be drawn from those studies about the safety of low sodium intake. More recently, data has been collected showing that very low levels are associated with increased mortality. These outcomes are reasonable because Na/K-ATPase requires sodium to function. Some well known poisons (digitalis, ouabain) work by disabling the sodium-potassium pump. No salt = No life.
Here is a graph from BMJ: Joint association of urinary sodium and potassium excretion with cardiovascular events and mortality: prospective cohort study.
all-cause mortality
And a similar graph from NEJM: Urinary Sodium and Potassium Excretion, Mortality, and Cardiovascular Events.
another graph
Of interest:
xiota
  • 186
  • You also seem to query about possibility of low blood pressure. It is possible, but is it relevant? If so, what have you seen with regard to low blood pressure and salt intake? – Chris Rogers May 26 '19 at 09:00
SODIUM REQUIREMENTS DEPEND ON THE SWEATING RATE
Adequate intake for sodium for moderately active adults can range from 460 to 1,500 mg/day, depending on whom you ask (Nutrition Australia, USDA). You can meet these intakes without adding salt to foods, especially if you eat foods that are already salted, for example, 100 g of bread can contain more than 500 mg of sodium. Foods that are not pre-salted, usually contain less than 100 mg of sodium per serving.
According to USDA, p.460:
the sodium AI [adequate intake] has been set at 1.5 g/day. Sodium intake at this level would be adequate to cover losses from sweating among those who are moderately active.
but
...the AI of 1.5 g/day does not apply to individuals who lose large volumes of sodium in sweat, such as competitive athletes and workers exposed to extreme heat stress....sweat losses during exercise in the heat may easily exceed 1 L/hour with a sodium concentration of greater than 0.8 to 1.15 g/L.
When sweating a lot, you may need more than 5 grams of sodium per day. Sweat rate and sodium loss during work in the heat (PubMed, 2008):
People working in moderately hot conditions for 10 hours on average will lose between 4.8 and 6 g of sodium (Na) equivalent to 12–15 g of salt (NaCl) depending on acclimatisation.
CURRENTLY RECOMMENDED SODIUM INTAKE TO PREVENT HEART DISEASE
The American Heart Association recommends no more than 2,300 mg of sodium a day and moving toward an ideal limit of no more than 1,500 mg per day for most adults.
EVIDENCE THAT LOW-SODIUM DIET MAY BE HARMFUL
It is good to be aware that not only high-sodium, but also low-sodium diet may be harmful for the heart.
Associations of urinary sodium excretion with cardiovascular events in individuals with and without hypertension: a pooled analysis of data from four studies (Lancet, 2016):
In summary, our results show an association between low sodium intake (vs moderate intake) and increased risk of clinical outcomes in those individuals with and without hypertension, whereas high sodium intake (greater than 6 g/day) was associated with an increased risk in individuals with hypertension. Our findings suggest that sodium reduction should be confined to only those individuals with hypertension and high sodium intake.
One recent study has found a similar relationship between salt intake and chronic kidney disease.
U-shaped dietary sodium–associated incidence of chronic kidney disease cautions against salt overrestriction in hypertension (Kidney-international.org, 2018):
In this population study salt intake is not associated with development of chronic kidney disease (CKD) in individuals with normal blood pressure, whereas in hypertensive individuals both low and high salt intakes are associated with increased incidence of CKD, similar to U-shaped associations between salt intake and mortality found in previous studies. The results contribute to the skepticism, which has questioned the present public health policy to reduce salt intake below 5.8 g.
Jan
  • 15,851
  • 24
  • 70
    Does your first statement stand within countries with very hot climates? – Chris Rogers May 23 '19 at 19:22
  • It seems that this does not, as the phrasing is unlucky in that source? Exercising in hot environments with so low sodium intake will first lead to cramps, then to more unpleasant than that. Fireman cramp, miners cramp etc. If anybody goes so low for a prolonged time he's in for trouble. Please expand on this, as currently I see a lot of circumstances were this low boundary will lead to hyponatremia resulting from orthorexia due to theoretical general recommendations. – LаngLаngС May 24 '19 at 09:31
  • Update: When sweating a lot, you may need more than 5 grams of sodium (12.5 g of salt) per day. – Jan May 24 '19 at 11:23
