I have connected 10 LEDs in series, the LEDs have a current rating: 20 mA which is 0.02 A and forward Voltage: 2V.
My power supply provides me with: 5V DC 2A
By using the formula down below:
$$R = \frac{vs-vf}{i} = 5 - \frac{2}{20} = 150 \Omega$$
I can see that LEDs need 150 ohm.
Which is in total \$10*150 = 1500\Omega\$
I connected: 1 k resistor, 2 x 150 ohm resistor and 2 x 100 ohm resistor which is a total of: 1500 ohm.
But the 10 LEDs dont turn on, what's wrong?
I can still turn 3-4 LEDs with or without the resistors.
Try to explain this down below please:
I tried to connect a single green led by itself without a resistor. It turned orange which is a sign that it needs a resistor.
Then I connected 150 ohm resistor to the led and it became green. I then changed the resistor value from 150 ohm to 1 k ohm, but it did not change the brightness of the led, it still the same green, no fading in brightness.
I tried to change the value to 33k ohm, it faded in brightness, but I can still see some greenish brightness in the LED.
What's wrong? Why is the LED responding like that to the resistor's value? I mean 1k ohm is much more then 150 ohm but it worked the same.
P.S.: I bought the resistors from China via eBay.
i tried to connect a single green led by it self without a resistor it turn orange which is a sign that it need resistor.using the led like this will damage it very fast – alexan_e Jan 22 '14 at 10:591k ohm is much more then 150 ohm but it Worked as sameif you use an ammeter you will see that the led current is not the same, your eye can't judge the current – alexan_e Jan 22 '14 at 11:05
