I am doing a system design presently which involves an OEM optical amplifier module (Dimensions: 220 x 250 x 60mm). It has got an operating temperature range from 0 deg. to 40 deg.C. However, my system is supposed to operate all the way from 60 deg.C down to -30 deg.C. The support personnel for the component informed that it can be ruggedized to make it operate in the required temperature range. Does anyone know how the ruggedization can be done?
Update
After testing the module, we have found that it can operate till 60 deg. C without any issues. Hence cooling mechanism at high temperatures is not required. All I need is a heating mechanism which can heat up the module when it goes to negative temperatures. Which type of heater will be best suited for this application? My system has a 28V DC input and I will have to heat up a face with 220mm x 250mm area.
If this is a commercial venture, make sure that others in your organization know what's going on, as this is the kind of thing that makes management unhappy if they find out after things ship.
– rfdave Apr 17 '14 at 11:00
