What are the items you have in your personal electronics tool kit?
Most important tool:
- A quality soldering iron. Mine's a Weller. Those Radio Shack pencil irons are useless, and will only make life more difficult.
- A wet sponge for cleaning the iron tip, several tips for the iron.
- Both desoldering braid and a solder sucker.
- Plenty of 60/40 solder, the silver bearing stuff doesn't flow nearly as well. A well stocked junkbox is extremely important. The more components you have to hand, the faster you can work.
- A good digital multimeter, I love my Fluke. Add to that a good analog multimeter, digital meters offer no sense of change over time.
- A dual channel 100MHz oscilloscope (mine's a tektronix mainframe that I scavenged).
- Good lighting! A third-hand rig or similar to hold parts and boards that are being soldered.
- A spectrum analyzer is very useful for radio work.
- A function generator.
- A sharp pair of flush cutting nippers.
- Several spools of different coloured 20 gauge hookup wire.
- Some people keep flux to hand, but I've never found I needed it.
- Assorted scraps of printed circuit board, or strip board - breadboards are very finicky and can add circuit-killing parasitic capacitance.
- The absolute best tool I've found for cutting PCB is a jeweler's saw. You can buy them from Contenti, and aren't very expensive. I've never seen anything use produce a better or faster cut.
I think that covers the bulk of it, it may seem like a lot of stuff but it's mostly small stuff. An LCR meter is handy, too. I have a foredom flexshaft, it's kind of like a Dremel but more powerful and higher quality. They're not cheap machines, but are a real life saver for modifying circuit boards.
    - 32,168
- 6
- 79
- 138
    - 1,022
- 7
- 5
                    I've got one of the digitally controlled soldering irons like they sell at Sparkfun (Aoyue, I think). Best tool purchase I've made. – edebill Dec 08 '09 at 19:56
                    I've just bought a ZD-916 temperature controlled soldering iron from Maplin and the difference between that and my cheapo pencil iron is amazing. Suddenly I can almost solder properly :) – Len Holgate Dec 08 '09 at 22:36
                    8Add a power supply to that list and you're golden. – Shawn J. Goff Dec 09 '09 at 02:16
                    +1 for a good answer but especially for the analog multimeter. I have none currently, only a couple digital ones. Oh sure, my brain is fast at interpreting numbers, but you just can't beat a swinging needle when monitoring certain things. – DarenW Oct 17 '10 at 03:39
                    1I went through your answer and added bullet-points, as it was really hard to follow without them. – Connor Wolf Jan 16 '13 at 05:50
                    What do you have against "radio shack" soldering irons? – Paul Jan 22 '14 at 01:31
                    Would you please provide you opinion about drills too? – Muhammad Abdulwanis Sep 19 '16 at 18:28
- Harbor Freight multimeter.  They actually work quite well.  RS has some slip-over test lead IC-hooks that work with the bundled test leads, totally worth the extra cost.  More expensive meters are better, but these are accurate enough (esp. for digital work: is it high? is it low?  it's cheaper than a logic probe!) and small enough to go in a small tackle/toolbox, and if something goes wrong it's easy to replace.  The transistor tester (shown below)
 saved me when I picked up some 2N2222's at RS and discovered that the package had the pinout backwards.  Seriously, even if you have a nicer meter, you will find uses for one of these. saved me when I picked up some 2N2222's at RS and discovered that the package had the pinout backwards.  Seriously, even if you have a nicer meter, you will find uses for one of these.
- Lots of IC-hook wires. Those things are fantastic, and are great for probing and prototyping. You can never have too many of those. I prefer these over alligator clips.
- Small/jewelers screwdrivers.
- Wire stripper.
- Small needle-nose pliers.
- Analog o-scope that was a cast-off from school.
- RS soldering irons. Honestly though, it's not worth getting the RS. Get a good iron. And solder wick, not that silly solder sucker bulb thing. I think this is the area I regret the most in my toolkit. I've used the small pencil iron three times and I botched a board with it because it didn't get hot enough.
- Arudino + Protoshield. Nice, small little prototyping platform.
- 6500K desk lamp lighting. Really, the daylight color helps. Very bright.
- Plastic compartment boxes for holding parts.
    - 2,790
- 1
- 14
- 51
    - 3,790
- 2
- 28
- 33
                    I also use the Transistor hFE tester. I fixed your link and added pics. – MicroservicesOnDDD Jun 15 '23 at 17:49
A couple of people have asked me about tools so I put together this list (below). I will put it on my site soon. If you think you may want to do SMD I would invest in a better iron than listed below (also a good light and a magnifier). My SMD tool recommendations are at http://tinyurl.com/5foeou
Tools
- (1) Weller WESD51 Soldering Station
 or Hakko 936ESD (diy list)
- (1) Well WSA350 Weller Smoke Absorber
- (5) WSA350F filter 3-pack
- (1) Panavise 308 Base Mount
- (1) Panavise 305 Base
- (1) Panavise 366 Jaws
- (1) Cooper Tools "Xcelite" 170M cutter
- (1) Ideal T-6 16-26AWG wire stripper
- (1) Ideal T-8 8-16AWG wire stripper
- (1) X-Acto x3201 No. 1 Knife
- (1) X-Acto x411 No. 11 Fine Point Blade
- Needle Nose Pliers, narrow tip
Supplies
- Kester 24-6337-6422 Solder
- Kester 2331-ZX Flux
- Chemtronics 5-25L Solder Wick
 Could add Chemtronics 10-25L Solder Wick
- 3M 2214 Wrist Strap
- 3M 8214 Anti-static Matt
- 5854/7 BL005 100ft 24AWG Blue Wire, Teflon
- 299 SV005 24AWG Bus Wire
- Extech EX330 Multimeter
 or Extech XTC-MM560 (sdiy list)
Custom circuits (not kits)
- 169P84WE (unclad) Vector board
- Vector T42-1 Clips
- Vector K24A Push pins
- 299/3 SV005 30AWG Bus Wire
- Extech Power Supply 382213
    - 32,168
- 6
- 79
- 138
    - 11,706
- 1
- 35
- 54
- 1k, 10k resistors, i rarely need other values, maybe 100s if I have LEDs.
- caps, 4.7uF, 1000pF, .1uF
- PICs, just some PICs, i think I have some pic16F876As, but I have access to three others also.
- LEDS, a few cheap ~10mA LEDs
- FLash memory, I never know when my project will need memory, I keep simple ATMEL memory, I can give a part number if wanted.
- ft232R, never know when I want some USB connectivity.
- I have other random parts, but they probably cycle pretty constantly.
I try to get a professor or my boss at work to buy my components, I do not tinker a large amount at home, but build little projects for my professor, or students in the class I help teach, to use, or I will build little projects to speed up a task at my job.
    - 13,412
- 8
- 62
- 85
                    I will admit, at work I have one cheap o-scope, at school I can get a hold of some nice equipment, but rarely need it. The most important thing for me at school is use of a current-limited power supply. At work we use batteries in our devices, so stuff blows up when we mess up. Nothing like shorting a car battery. – Kortuk Dec 06 '09 at 01:02
Tool wise I have: Multimeter, probe, pocket oscilloscope from seed studio, solder iron, screw drivers, and other various hand tools.
Bench wise I have: tektronix oscilloscope (from school), programmable power supply(from school), function generator
Component wise: Too many to list here. I am one of those people that stores love to see coming. I see something and think to myself "I might be able to use that later" and so I stock up in bulk. Or my neighbors throw out stuff and I take it and rip parts off it (my wife hates that). She thinks I could be on that show called "Hoarders" but for electronic components. Then I lucked out because my school upgraded their labs, and my professor gave me everything they had because the school was just going to throw them out!
    - 555
- 1
- 4
- 10
                    2I'm a big advocate of buying components in bulk. They have near infinite shelf life(except for electrolytics), and in bulk the price can halve. When I buy transistors I tend to buy 75 or 100 at a time. When I do that, I pay less than half per transistor, and I spread the shipping across more components. – wackyvorlon Dec 05 '09 at 20:18
                    1I always buy in bulk from mouser/digikey(normally mouser) for parts, our school also does a weekly order that I can place parts on and have them free of shipping. – Kortuk Dec 06 '09 at 01:00
I make sure I have a 1/8" stereo jack on a length of wire so I can plug my breadboard projects straight into my computers audio input. I also have some paperclips, that I normally use for bending into little brackets, that can hold various strange shaped components onto the breadboard, i.e little piezo buzzers or speakers. And last but not least, Blue Tac, I can't stress enough how many times it's helped me out in a tight spot, it's useful for all sorts, not to mention holding wires in place whilst soldering. I also have a lamp, it's an eco-friendly 2.5w super massive LED thingy. It's got a swan neck, it's really bright and at £20 from Ikea it's a darn site cheaper than a proper technicians desk lamp.
Jim.
    - 3,375
- 2
- 30
- 39
                    stereo input into your speaker? Now that's making due with the bare essentials! lol – Earlz Apr 18 '10 at 07:29
Here are some of the tools I find myself using most often:
- Weller WES51 soldering iron
- Panavise Jr.
- Fluke 87V multimeter
- PHT-PYT-4 wire strippers (don't buy the cheap chinese knockoffs. Mine were unusable.)
- Rigol DS1052E oscilloscope (somewhat expensive, but even as a relative beginner it's been an invaluable learning tool for showing what's actually going on with the voltage levels inside a circuit.)
- Cooper Tools "Xcelite" 170M cutter
- Elexp 060210 long nose pliers (I find myself using these constantly. Best $2 I ever spent.)
- Soldapullt deluxe
- Scotch tape for holding components in whilst I'm soldering them on the underside of the board.
I use a 12V computer fan hooked up to my three output variable power supply to dissipate solder fumes. Seems to work fine for now.
    - 4,355
- 6
- 25
- 20
- A pencil (and sharpener). Molten tin won't stick to the carbon of the pencil, so you can use it to open a solder pad or solder bridge. It is in the same category as desoldering braid and a solder sucker.
- I like to use one small and cheap breadboard for soldering. It holds pins nicely in place while I solder them. I use it only for soldering to prevent flux and resin from ending up on other components. Same category as a third-hand rig.
- Antistatic foam to keep IC's safe.
- A drawer full of old power supplies (SMPS, that came with telephones, monitors, network equipment, ... at various voltages and currents) saved from the junk yard.
- Order components in bulk: 10, 50, 100, 500+ pcs. prices can drop incredibly if you find the right shops.
- Couple universal heat sinks and mounting material.
- Pin headers, lots of them. I often push the pins out to reuse them by pushing them eg. into a breadboard (or female header on a breakout) so I can easily connect a multimeter to it.
- Lots of single pin 2.54mm Dupont male and female connector wires to make interconnections between male headers.
- Battery holders for 1 and 4 penlights.
- IC sockets.
- Account credentials to https://electronics.stackexchange.com/
