If I use an LM311 Comparator, then we are required to connect a pull up resistor at the output. Does the square wave output depends on the value of the voltage the resistor pulls up to?
Would it be that if i had a 5V on the pull up, then the output would be a square wave with 0V to 5V(max). And for a 12V pull up - a 12V to 0V Square wave?
Sherby
  • 2,356
  • 27
  • 46
Yes, the pull-up resistor will pull the output up to whatever voltage it is connected to, unless something else connected to that output prevents the output from rising to the full supply voltage.
Peter Bennett
  • 59,212
  • 49
  • 132
