11
I have read the Wikipedia article Three-state logic, but it is not clear enough. What is a more simple explanation for what a three-state circuit is?
When and where do we use it? What has CMOS to do with three-state circuits?
Null
  • 7,603
  • 17
  • 36
  • 48
Despre Femei
  • 365
Normal push-pull outputs drive the output either high or low by turning one of the output transistors on and the other off. Tri-state outputs can turn both transistors off, effectively cutting off the output completely. This allows another output on the same wire to drive it either high or low without creating a short circuit between chips.
Tri-state outputs can be implemented with either BJTs or MOSFETs, so there is no direct relation between them and CMOS.
Ignacio Vazquez-Abrams
  • 48,488
  • 73
  • 103
Tri-state may be considered as the high impedance state of a digital pin, wich was born to be 0 or 1
(ideally "0" = gnd = short circuit to the ground = very low impedance) ( "1" = 5V [ttl] = short circuit to vcc).
When you define a processor pin as an input, it usually become high impedance (tri state) to listen to the arriving data, may it be a button press or serial data, pulse, whatever.
m33600
  • 78
