I am using a Meanwell SDR-120-12 power supply for a project. I noticed it has terminals for "DC OK" which the datasheet refers to as a relay contact rated for
60Vdc/0.3A, 30Vdc/1A, 30Vac/0.5A resistive load
It also says:
Contact Close = PSU turns on / DC OK.
Contact Open = PSU turns off / DC Fail.
Contact Ratings (max.) = 30V / 1A resistive load
The block diagram seems to show that this is a relay that's operated by the power supply being energized. I assume this contact might stay open if the power supply did not pass some sort of self test at power-up? If that's true, then is the "DC OK" terminal meant as a means for equipment to detect if power is fully available (sort of like how a computer PSU communicates to a motherboard)?
How is this different from simply using output power from the supply to operate a device and not utilizing the relay at all?
