The NeverWet superhydrophobic spray is becoming available to consumers.
Are materials like this suitable for protecting circuit boards that may be exposed to water?
http://lancasteronline.com/article/local/861483_Magical-NeverWet-arrives-in-stores.html
Mark Harrison
  • 10,651
  • 27
  • 70
  • 99
  • You can protect boards, or yourself, from water by covering the board/yourself with plastic. A raincoat. Silicon coating is used when you don't want to wear a raincoat. Since PCB's aren't made of fabric, this is not an issue. If it was, you probably would not use a spray coating. Spray coating is used when dip or paint is too dificult. – david Jun 22 '13 at 07:02
  • Does the coating some how trap heat? Kind of like wrapping ones self in plastic and going for a run, could be a bad idea, no?
  • –  Jun 25 '13 at 13:34
