I'm using ngspice and trying to add UIC at the end of the TRAN statement, but I get an error:
$ ngspice 1 -> tran 10m 5 UIC
Warning:  Error: unknown parameter on .tran - ignored
Why does this happen and how can I make it work?
ngspice compiled from ngspice revision 20
Thank you.
Dor
  • 1,165
  • 16
NGSPICE version 20 is much too old. Please upgrade to version 26. The current version has no problem with UIC.
PS: "ngspice 1 -> tran 10m 5 UIC" should probably be "ngspice 1 -> tran 10m 5 0 10ms UIC" (parameters are extracted by position).
Marcel Hendrix
  • 176
UIC = Use Initial Conditions and is used in conjunction with the IC= specification for inductors and capacitors.
They may not support this and instead expect you to use .IC on node voltages and currents rather than on a component basis.
placeholder
  • 30,170
  • 63
  • 110
