There is a circuit based on TTL( transistor transistor logic I think) . The signals at points A B C D are described. I am new with this TTL, could you help me decompose this united circuit into the logic components which it consists from? Thanks.
Chris95
  • 13
  • Looks more like RTL (Resistor-Transistor Logic). Cute, the PNPs are "upside down", but so is the supply; reminiscent of 50s-60s era germanium circuits. – Tim Williams Mar 30 '24 at 08:25
  • Hello Mr. Williams, what is the structures you see in here which is combining this circuit?Thanks. – Chris95 Mar 30 '24 at 09:42
  • Could you explain what V_CON is, and what J11-J14 are or what might be attached to them? – Tim Williams Mar 30 '24 at 10:38
  • Hello Mr Williams, I think the X means that Vcon is non relevant.Its attached J11 is i think going to be attach to a gate of a mosfet. – Chris95 Mar 30 '24 at 11:41
  • Hello Mr Williams, what is the substructure logic here? – Chris95 Mar 30 '24 at 14:27
It seems to be a simple inverter.
Assuming no other connections, resistors and supply as shown, we can simplify the circuit as so:
schematic
which has a DC transfer function from V1 (A) to D,
give or take the setting of your R13, here set all the way towards C.
It's more or less an emitter follower-buffered negative-voltage (PNP type) RTL inverter, with level shift at the input.
The Darlington follower (Q2 into Q3) doesn't seem very useful, but without knowledge of application and ratings, that's neither here nor there.
Tim Williams
  • 33,670
  • 22
  • 95
  • Hello Mr. Williams, point A is a pulse of 0-3.3V at 120ns.I am trying to understand and simulate each step. given my original circuit could you please explain what is the logic from point A to B? they have an intresting diode in parralel with capacitor, and some things near the -2.5V power supply. whatis the logic in that?Thanks. – Chris95 Mar 30 '24 at 19:12
  • There is no logic function, simply a level shift. You can simulate the circuit to see voltages. LM4040 is a 2.5V regulator that has been replaced here with a voltage source. – Tim Williams Mar 31 '24 at 01:15
