I found that they sell UNO Starter kits and Leonardo Starter kits. There are many different products. My eyes are so busy. I am a greenhand. If I want to buy a stater kit, which one should I buy? UNO or Leonardo?
Start by looking at the product page at the Arduino website: Leonardo and Uno. A practical difference is that the Uno has a chip that can easily be replaced when you manage to blow up one or more pin drivers. – jippie May 24 '13 at 07:35
Thank you for your answer. I just found that the differences are the Microcontroller, Digital I/O Pins, Analog Input Pins and SRAM. Except these, their function are the same? – Sue2013 May 24 '13 at 07:39
5For a beginner, the Uno would be a recommendation. – Anindo Ghosh May 24 '13 at 07:50
Frankly, I heard a lot about UNO and seldom hear about Leonardo. In this case, I am quite interested in it and want to know the difference. Really thank you for your advice. Nice~~~ – Sue2013 May 24 '13 at 08:00
Leonardo is much younger than Uno, that's why you hear more about Leo. – jippie May 24 '13 at 08:05
As shown in this series of comments, there is no WRONG choice; the important is to just get started. You will make mistakes, as we all do (if you're not making mistakes, you're not pushing yourself, you're not learning). Coming to these forums is definitely a good start! – Jul 13 '14 at 20:59
How is that question is not closed?! – May 07 '16 at 06:14
Let me make a proper writeup of comments.
I just found that the differences are the Microcontroller, Digital I/O Pins, Analog Input Pins and SRAM. Except these, their function are the same? – Sue2013 34 mins ago 2
From an practical and average Arduino user perspective the pin functionality will be the same. For the nitty gritty details refer to the datasheet ATmega32u4 for Leonardo and ATmega328 for UNO
Frankly, I heard a lot about UNO and seldom hear about Leonardo. In this case, I am quite interested in it and want to know the difference. Really thank you for your advice. Nice~~~ – Sue2013 13 mins ago
Leonardo is much younger than Uno, that's why you hear more about Leo. The blog also mentions a few nice Leonardo features:
- Simpler and cheaper hardware;
- USB is integrated in main processor;
- Able to implement other protocols than serial UART (eg. act as mouse or keyboard);
- More analog inputs (12) and one more PWM pin than UNO;
- R3 header pinout: I2C is aways in the same place, regardless of the exact microcontroller on the board. This makes R3 shields more universal. The IOREF pin can inform a shield whether the Arduino is using a 3v3 or 5V micro. R3 shields are more future proof.
- 33,221
- 16
- 95
- 161
Note that your last bullet point is not an advantage of the Leonardo over the Uno R3, the current version of the Uno (that's what the "R3" refers to). The Uno R3 has the duplicate I2C pins and IOREF pin, just like the Leonardo; the older versions of the Uno (the original and R2) do not. – kwc Apr 18 '14 at 00:58
The Leonardo is 20% cheaper which might be important if you have almost no money. It has a few extra capabilities but lack of these are unlikely to hinder most beginners learning about Arduino and microprocessors. See Uno vs Leonardo
The Uno uses a replaceable microprocessor where the Leonardo uses a fixed surface mount device (SMD). If you damage the microprocessor you can replace it. You can damage the microprocessor by connecting it's IO pins to the wrong voltage or allowing too much current to flow. You can also have spare microprocessor chips with different programs loaded in each or use the Uno to load programs into microprocessor chips that you intend to use in home-built circuit boards.
- 14,710
- 5
- 39
- 80
The major difference between Uno and Leonardo is that Leonardo has an ATmega32u4 which has support for the USB, whereas the UNO has ATmega328 which doesn't have the USB support onboard.
So how this affects you and the cost:
Since Leonardo has USB support onboard it doesn't require an external microcontroller for USB connection. Whereas the UNO requires an additional microcontroller to provide the USB capability.
Cost wise Leonardo is cheaper than UNO by 20%.
So, go for Leonardo as it is low cost. Then you can harness the USB capability of Leonardo if you want.
The Leonardo is a very nice board, but compatibility with shields can be a bit problematic, since the SPI pins are available exclusively from the ICSP header. There are also other subtle differences.
For a beginner, the Uno might be a better choice, except if you either know you’re not planning to buy shields, or if you have plans for fancy USB projects.
- 1,601
- 2
- 12
- 18
