I learnt recently about the RBZ80 ; a vintage valve receiver which used variable permeability tuning rather than variable capacitor tuning.
In thinking about the possible reasons for permeability tuning in lieu of capacitive tuning the thoughts that come immediately to mind as follows
The receiver was designed for hostile environment. Air dielectric would be bulky. Any other dielectric may be damaged/corrupted by exposure to the elements (e.g. salt water).
What advantages does permeability tuning offer as compared to capacitive tuning?
Everyone
  • 3,021
  • 35
  • 49
  • It wasn't just the military that used this. Most car radios were built this way until digital tuners were developed. – gbarry May 23 '13 at 14:26
    Many of Ten-Tec's old amateur transceivers used permeability-tuned oscillators, and they're noted for their low levels of background noise. – TMN May 23 '13 at 19:18
The permeability tuning (variable inductance) is essentially a slug of ferrite that can be screwed in and out of a coil wound around a former. Once the circuit is tuned wax can be used to seal it into position or the screw thread can be locked mechanically. The variable capacitor has large inter-meshing plates that are subject to mechanical damage or vibration and is physically a large component (size matters). The range of tuning using variable capacitors is greater than inductive tuning for a single tuning coil. Switching coils (bands) is easy to do. Variable capacitors are quite expensive (not a military consideration) to produce so there is a cost saving as well. For a portable radio used in warfare size, mechanical robustness and functionality are important.
JIm Dearden
  • 19,036
  • 30
  • 40
I remember seeing an old radio with slug tuning and two seperate inductors were slug-tuned in-tandem. I'm guessing here but that possibly performed the function of input tuning and local oscillator tuning thus keeping the LO 455kHz away from the desired radio channel. I know that dual variable caps were often used for the same purpose but given the physical size of variable caps for AM broadcast bands I think ferrite slug tuning would win-out.
I would also consider that tooling up for ferrite slugs and coils is simpler and, if design adjustments needed to be made, a few turns added or removed would be simpler than altering the plates of the capacitor. Different ferrite slugs gives yet another option over caps.
I also remember the push-button pre-select tuning on car radios - although the mechanism was a little tortuous on ferrite tuners (the "system" mechancially memorized the slug position), I'm struggling to visualize how this would work with variable caps (which of course rely on rotation of the interleaved plates).
I'm also pondering the prospect of (say) 3 or 4 slugs operating in tandem negating the need for a local oscillator, mixer and IF strip because the RF selectivity would probably be good-enough to funtion as a half-decent AM radio.
EDIT A day later and I've thought of yet another advantage - tuning across a band of frequencies for the desired channel is OK but for either a variable cap or variable inductor tuning, the Q of the resonance changes from one end of the dial to the other. I can imagine that if the ferrite slug introduced into the winding was low loss (on introducing the slug) and gradually got "lossier" along its length, as inductance rose (and selection frequency dropped), the Q of the circuit could be maintained flat (or nearly flat).
Andy aka
  • 456,226
  • 28
  • 367
  • 807
  • Yes, I remember the push button tuning as well. They were a mechanical nightmare. The first TV sets (405 line) operated with turret tuners - a big rotary switch that had the tuning circuits built into a push in strip so that you set up the order of channels. – JIm Dearden May 24 '13 at 18:14
  • I had fun and games with a TRF reciever like Andy postulated.I used 3 slugs and it was marginal .I used the RF and ANT slugs in a KQ hopefuly equals 1 BPF and used the third slug which was the OSC .The unexpected or interesting part was that the osc coil tracked fine with a capacitance increase .I got good sound due to the lack of sideband cutting . – Autistic Oct 12 '15 at 10:35
One advantage is that permeability-tuned coils are quite a bit smaller than variable capacitors. Another is that permeability-tuned coils can be more temperature stable than ganged capacitors. Another is that you have the opportunity to linearise tuning by using a variable pitch thread.
Source: Radio Designers' Handbook.
The Quad FM and FM2 tuners are further examples of the technique.
user207421
  • 880
  • 18
