So, I'm trying to analyze how the circuit in this question behaves when subject to reverse battery (vs. being driven from OUT to IN), and I'm running into a severe snag in the process, though. It appears in SPICE simulations that with most typical supply voltages (5V or more), the PNP B-E junctions would get zenered if you apply reverse battery (negative voltage) on the left-hand side of the circuit while there is another power source feeding the right side.
However, SPICE does not simulate B-E Zener breakdown in BJTs at all, never mind what the collector of the right-hand BJT is doing while the B-E junctions are zenered. I plan to build the circuit and test it (as well as a potential fix with some series diodes), but before I do, what should I be expecting the collector of the right-hand transistor to do while its B-E junction is in Zener breakdown? (Or, will the FET be on, off, or somewhere in between, for that matter?)
