The below is a reverse polarity circuit with additional components around it. I would like to understand the exact functionality of the additional circuitry in dotted lines.
            Asked
            Active
            Viewed 87 times
                    1Ravi Prasad - Hi, Re: "I came across the following reverse polarity circuit" Where did you come across it? To comply with the site rule on referencing, you should include a suitable citation for material copied or adapted and posted on Stack Exchange. For an online source, adding the webpage / PDF / video title & its link are the minimum; see the rule above for more details. Please [edit] your question to add a suitable reference. || Please see the [tour] & [help] as the site rules differ from typical forums. TY – SamGibson Jan 08 '24 at 11:44
                    1Please double-check your source. It looks like Q2 should be PNP rather than NPN. As an NPN, there is no source for its base current. But as a PNP (emitter connected to Vout), it would actively clamp the gate of M1 in the off state as soon as Q1 turns on as a result of Vin becoming less than Vout. – Dave Tweed Jan 08 '24 at 12:42
                    Hi Dave, BC846BPN chip contains npn pnp transistors. Connections are same exactly shown circuit. – Ravi Prasad Jan 11 '24 at 15:32
                    I understand that, but it still doesn't make sense to use a NPN in that position. – Dave Tweed Jan 12 '24 at 12:44
