General Information About the Project
I am trying to design a zero-crossing detector circuit for convert the sinusoidal signal from an ultrasonic transducer to a square wave. Here is the image of ultrasonic transducer:
pair of transducer
To trigger the transmitter transducer I generate 40kHz square wave with SG3525. Square wave is 12Vpp and duty cycle is 49%. Oscilloscope output shown below:
PWM signal of transmitter
When I drive the transmitter with this pwm wave, I can read the signals from receiver sensor. Regardless of the location of the transmitter, the receiver always receives a signal at a frequency of 40kHz. What changes is the amplitude value and phase shift. Here is the receiver signal outputs below:
Receiver Signals
These measurements performed at different times, so frequency values of transmitter and receiver shown not equal. Even if their frequency values don't look compatible, they are compatible.
Zero-Crossing Detector
I want to convert the receiver's sinusoidal signal into a square wave to analyse the phase-shift between signals of transmitter and receiver. I used a Schmitt Trigger circuit, but it created a phase shift and could not successfully convert the sine wave into a square wave. Then, I decided to build the circuit with BJTs. The circuit that I built, and the output shown below:
schematic
Zero-Crossing Detector Output
Experiment
I tested the circuit shown above on a breadboard and analyse the circuit with an oscilloscope. My test steps are as follows:
  1. I test the circuit with function generator with different voltages and frequencies.
  2. I test the circuit with the receiver's output signal.
1st Experiment with Function Generator
When I analyse the circuit, I applied the voltage values from 1V to 10V and frequency value from 1kHz to 40kHz. When I apply a frequency value above around 5kHz, the square wave produced by the circuit begins to distort. Here are the images:
for 10Vpp and 1kHz:
1khz output
for 10Vpp and 7kHz:
7khz output
for 6Vpp and 40kHz:
40khz output
2nd Experiment with Receiver
I tested the signals of receiver to convert them into square waves. To trigger the receiver, I used the SG3525 PWM circuit and transmitter. Bu it does not work on the circuit. I read sinusoidal 40kHZ 3Vpp wave from receiver. Then I connect the signal into the circuit to examine the conversion, but it did not work.
Results
When I feed the circuit with a sine wave using the Function Generator, I can receive a square wave at low frequencies. But when I increase the frequency (about 2-3 kHz and above) the square wave starts to distort. When I give the signals from the receiver to the relevant circuit, I cannot get any output. Not even a distorted signal occurs.
Question
I want to convert the sinusoidal wave coming from the receiver into a square wave, compare it with the wave I created in the transmitter, and obtain the phase shift by looking at this. However, the circuit I built to convert the sinusoidal wave into a square wave is malfunctioning at high frequencies. At the same time, this circuit does not even process the signals coming from the Receiver.
If this method I have applied is a logical method to see the phase shift, why can't I process the receiver's signal? If you know a more logical way to see the phase shift, I would be happy if you share it with me.
Best regards
kkrgzz
  • 121
  • Did you try with 2N390x BJTs? – Rohat Kılıç Jan 03 '24 at 08:56
  • @RohatKılıç I didn't have the chance to try it because I couldn't supply it. I will review the datasheet, buy it and try it. Thanks for review! – kkrgzz Jan 03 '24 at 09:29
    @kkrgzz Handling a full order of magnitude difference in swing at the input, without any change in the duty cycle at the output is going to be a challenge. But I gather that's what happens given the distance from the transmitter. I also don't think the ultrasonic receiver has an output impedance of 0 (your test supply in simulation.) You need to be very specific about the ultrasonic receiver's output details. Everything flows out of that. Start there -- what's the device, exactly, and it's datasheet? (Phase shift is a whole other topic.) – periblepsis Jan 03 '24 at 09:59
    @kkrgzz In simulation I generated this pair of timing pulses to illustrate what I mean. With a well-designed circuit (yours is not) the green phase pulses show things with $1:\text{V}$ input and the dark blue phase pulses show the same circuit but with $10:\text{V}$ input. Note that the higher voltage input will have a larger magnitude dV/dt and this will *pull* the phase up earlier relative to the transmitter event. Keeping that invariant over differing signal heights will be a challenge, as I said earlier. – periblepsis Jan 03 '24 at 10:10
    @kkrgzz But that's not all. From comparing the green and dark blue pulses you should also see that phase shift isn't the same for the rising and falling events -- that is *also* dependent upon the signal input magnitude. So. I must emphasize in every way possible that it is going to be a challenge to deal with an order of magnitude difference in source magnitude. This is part of the reason why the receiver details are vital. – periblepsis Jan 03 '24 at 10:13
  • Thanks for your precious answers! Receiver details for ultrasonic sensors do not clear. There are several receiver datasheets, but the companies that sell does not supply the datasheet unfortunately. Here is the link of transducers of Murata Datasheet – kkrgzz Jan 03 '24 at 10:45
    @kkrgzz One more thing I forgot to add. The receiver itself will have it's own phase shift. Your scope diagrams do *not* show the timing of the transmitter *and also* in parallel the sine wave at the receiver relative to it for the minimum fixed distance and then for one more *different* fixed distance away that is nearer the maximum. I suspect that the delays will not draw a line going back to (0,0) on a chart -- that there will be an "offset" to calibrate, different for each paring of Tx and Rx devices. You need a data logbook and to start taking lots of experimental notes. – periblepsis Jan 03 '24 at 10:49
    @kkrgzz You will need to set up a series of different experiments. One experiment needed to explore the output impedance of the receiver and its variations over dozens of devices (if possible.) One experiment to explore variations in the receiver offset relative to the transmitter pulse. This should be studied at at least three different distances, as well. And experiments to study your desired approach using a Schmitt trigger circuit (which isn't designed correctly, so that's just one more thing piled upon others) and how the Schmitt trigger varies with input magnitude, rising and falling. – periblepsis Jan 03 '24 at 10:54
    @kkrgzz Your goals also need to be clearly stated. What are your repeatability specs? What are your precision specs? What are your accuracy specs? What about trueness? Over what range of distances? And so on. The logbook will not be finished on a single page!!! This will sprawl across dozens if not hundreds of pages when you are done. No datasheet? Then you have your work cut out for you. ;) – periblepsis Jan 03 '24 at 10:55
    @kkrgzz I've written a little something on Schmitt triggers that provides some research paper references for Schmitt trigger designs and their analysis. Yet another set of sources to study and to replicate the important parts of in your logbook. And if you do look there you may perhaps notice some differences from your design. Also, there will of course also be vagaries in air density, moisture, temperature... Did I say you have your work cut out for you? – periblepsis Jan 03 '24 at 11:00
    Are you taking output to oscilloscope from Q2's collector? Have you used a 1X oscilloscope probe? You might be adding approximately 100pf capacitance to R2 (100k) resistor, causing an RC rise time constant of 10 microseconds. As soon as you remove the probe, Q2 becomes much more square. Can you try a 10X attenuator probe? It should look more square because 'scope probe cable capacitance is now less-affecting your circuit. – glen_geek Jan 03 '24 at 13:27
    @glen_geek Thanks for that. There's so much to be aware of in situations like this. And every little bit matters. Appreciated the addition! – periblepsis Jan 03 '24 at 13:57
  • @periblepsis Thank you for sharing your valuable information with me. I reviewed the information you share and I will continue to review. – kkrgzz Jan 04 '24 at 09:44
Assuming a noiseless, perfectly sinusoidal, ideal voltage source, a \$12\:\text{V}\$ power supply rail, and that you only need one pulse or edge per full \$360^\circ\$ cycle consider the following experiment:
schematic
(For the following tests please ignore the negative-going edge at OUT. You don't care about that. It's not important.)
Here, I've taken seriously your order-of-magnitude variation in the input voltage peak. And I'm trying to find a circuit that will allow you to handle it, while at the same time attempting to achieve other important goals. Hopefully, the above circuit provides some useful thoughts in that direction.
Set \$R_3\$ and \$R_{11}\$ to their midpoints and apply a \$50\:\Omega\$ signal generator output set to \$10\:\text{V}\$ peak sine source to IN. Adjust \$R_{11}\$ until you get a sharp positive-going edge at OUT that is exactly aligned with the zero-cross of your input source.
Now switch over to a \$1\:\text{V}\$ peak sine source in your signal generator (same output impedance) to IN. Adjust \$R_3\$ until you get a sharp positive-going edge at OUT that is exactly aligned with the zero-cross of your input source.
At this point you have calibrated the Schmitt trigger and I think it will work to provide a positive-going edge at the zero-crossing point, once per \$360^\circ\$ cycle regardless of the magnitude of your receiver signal.
Note: Don't use a solderless breadboard. (Or, use it, but worry.) There are random order-of-magnitude of \$10\:\text{pF}\$ capacitances floating about all over such breadboards. Large enough to be a pain. Small enough to possibly not matter... sometimes. Best to avoid them, if possible. Use construction techniques such as manhattan, rat’s nest, dead bug, live bug, etc. I prefer to avoid solderless breadboards when I'm uncertain about trace capacitances. As glen_geek also points out, scope probes also can matter. And when you are trying to evaluate Schmitt trigger circuits it is better to avoid confusion than to embrace it. So mitigate as much as you can.
(Finally, I've specifically avoided specifying the BJTs because the above design should accommodate a variety of small-signal devices.)
Here's a simulation using LTspice stepping the peak voltage from $1:\text{V}\$ to \$10:\text{V}$.
Pretty close fit.
Best wishes, kkrgzz...
periblepsis
  • 8,575
  • 18
  • Thank you for the circuit. I simulated the circuit, but I didn't get a successful result. I will make changes in line with the information you describe and simulate it again. At the same time trying with FET, the use of comparator is among my plans. I will try them and share the results. Thank you for all this effort! – kkrgzz Jan 04 '24 at 09:48
  • @kkrgzz I added the simulation output using some tweaked values for the pots. – periblepsis Jan 04 '24 at 09:58
Instead of using a zero-crossing detector, you can convert a sine wave to a square wave directly using a comparator.
schematic
Math Keeps Me Busy
  • 23,260
  • 75
  • Thanks for your review! I tried the comparator circuit with LM741 in LTSpice but it did not work properly. At 40kHz it generates triangular wave output. I searched for comparator circuits but most of them built for 50/60Hz. – kkrgzz Jan 04 '24 at 10:01
    @kkrgzz LM741 is not a comparator, it is an op-amp, and it's use is deprecated by virtually everyone on this site. If you are looking for an inexpensive comparator, in thru hole packaging, the LM311 is a reasonable choice, but beware of counterfeits. Buy from a reputable source like Mouser, Digikey or equivalent in your country. Parts from Amazon or AliExpress might be counterfeit and disappointing. I will update my answer with a LTSpice simulation using an LM311. – Math Keeps Me Busy Jan 04 '24 at 14:56
