I have element 'A', the receiver, connected to earth, which powers modules 'B' and 'C', the signal sources, unconnected to earth. 'B' sends a differential line signal, and 'C' sends an analog signal. My cables from 'A' to 'B' and from 'A' to 'C' have ground wires.
I read we usually connect the cable's shield to the ground on the signal source's side. In my case, that would be to elements 'B' and 'C'. However, elements 'B' and 'C' are powered by element 'A', the signal receiver. Therefore, should I connect my shields to the ground on the side of element 'A', the signal receiver, instead?
Edit:
- Differential line of 'B' is RS-422 with twisted pairs and a maximum frequency of 10 MHz
- Analog signals of 'C' are from temperature, humidity and pressure sensors.
- Power and ground are twisted pairs in both cables
- Analog and ground are twisted pairs in cable 'C' to 'A'
- 'A' has its ground plane connected to earth via 4 screws.
- There is no galvanic isolation.
- Both cable lengths are a maximum of 3 meters.
