I have been in the process of remaking Ben Eater's 8-bit-computer, and have a few questions. I got to the part where the clock, which consists of 3x 555 timer, is connected with logic gates. However, even after testing every IC and ensuring it works, I do not get the desired output.
Pin 3 of the astable one is connected to pin 1 of the AND gate. Pin 3 of the astable one is connected to pin 2 of the AND gate, and also via an inverter to to pin 4 of the AND gate. Pin 3 of the monostable one is connected to pin 5 of the AND.
The only differences between my circuit and the one Ben Eater made are the following:
- The bistable 555 isn't controlled by a button, but by manually connecting either the trigger pin or the reset pin to VCC.
- The SN74LS32, which is sadly not available where I'm from, has been replaced by the 74HC32, since I'm new to electronics I'm not quite sure if this is a problem. Again, all of the ICs work fine and everything is connected as in the tutorial.
