177
We often see component values of 4.7K Ohm, 470uF, or 0.47uH. For example, digikey has millions of 4.7uF ceramic capacitors, and not a single 4.8uF or 4.6uF and only 1 listed for 4.5uF (specialty product).
What's so special about the value 4.7 that sets so far apart from say 4.6 or 4.8 or even 4.4 since in the 3.. series we usually 3.3,33, etc. How did these numbers come to be so entrenched? Perhaps a historical reason?
MandoMando
  • 3,262
  • 22
  • 30
    @MichaelKjörling: that's funny, when I saw the title of this question I immediately thought of the ST:VOY episode where Neelix overhears and uses "Engineering authorization Omega-4-7" - never realized the use of 47 was so deliberate. – Michael May 04 '13 at 05:09
    The number 47 comes up in almost every episode of TNG and Voyager. I'm not quite geeky enough to know the backstory on that, but maybe it's related to this question. – Kevin Krumwiede Aug 01 '14 at 04:40
    @KevinKrumwiede this seems to be an explanation, although I don't think it's the EE answer – user2813274 Sep 15 '14 at 00:29
    Related : https://en.wikipedia.org/wiki/Preferred_number, https://en.wikipedia.org/wiki/Preferred_number#E_series – Always Confused Jul 01 '16 at 19:33
    Is it something like 1:2:2:5 Ratio used in weight-box and the antique "Resistance-Box" ? (read http://telephonecollecting.org/resistance.html A typical box may contain coils with the following numbers of ohms: 1, 2, 2, 5, 10, 20, 20, 50, 100, 200, 200, 500, up to 10,000 in some boxes") – Always Confused Jul 01 '16 at 19:45
  • Similar: http://electronics.stackexchange.com/questions/123453/why-resistor-values-are-non-linear-what-makes-sense-in-470-ohm – Always Confused Jul 01 '16 at 19:54
6 Answers6
148
Due to resistor colour-coding bands on leaded components two-significant digits were preferred and I reckon this graph speaks for itself: -
These are the 13 resistors that span 10 to 100 in the old 10% series and they are 10, 12, 15, 18, 22, 27, 33, 39, 47, 56, 68, 82, 100. I've plotted the resistor number (1 to 13) against the log of resistance. This, plus the desire for two-significant digits, looks like a good reason. I tried offsetting a few preferred values by +/-1 and the graph wasn't as straight.
There are 12 values from 10 to 82 hence E12 series. There are 24 values in the E24 range.
EDIT - the magic number for the E12 series is the 12th root of ten. This equals approximately 1.21152766 and is the theoretical ratio the next highest resistor value has to be compared to the current value i.e. 10K becomes 12.115k etc.
For the E24 series, the magic number is the 24th root of ten (not suprisingly)
It's interesting to note that a slightly better straight line is got with several values in the range reduced. Here are the theoretical values to three significant digits: -
10.1, 12.1, 14.7, 17.8, 21.5, 26.1, 31.6, 38.3, 46.4, 56.2, 68.1 and 82.5
Clearly 27 ought to be 26, 33 ought to be 32, 39 ought to be 38 and 47 ought to be 46. Maybe 82 should be 83 as well. Here's the graph of traditional E12 series (blue) versus exact (green): -
So maybe the popularity of 47 is based on some poor maths?
Andy aka
  • 456,226
  • 28
  • 367
  • 807
    The value "33" seems a bit curious, since sqrt(10) is 3.1622. If in addition to the "smooth" series there were also values which were nominally centered on "2.000" and "5.000", then it would make sense to have a value which was nominally centered on "3.000" and "3.333" [so as to allow some nice whole-number ratios of nominal values], but the series doesn't seem to allow any nice whole-number ratios. – supercat May 03 '13 at 15:23
    It's not about integers at all. The same sequence going from 1 to 10 instead of from 10 to 100 will have fractional digits. The issue is trying to stay to two significant figures, not integers. – Olin Lathrop May 03 '13 at 19:33
  • @OlinLathrop yes you are right - I was being a bit flippant when I wrote it - I did consider writing about the banding on standard leaded resistors and the number of sig digits - I'll change it - thankyou – Andy aka May 03 '13 at 19:43
    @supercat FWIW, it was E6 that was used in the first place; IMO the (still arguably most common) values 10 15 22 33 were chosen for simplicity. Although 10^1/6 = 1.47..., taking those exact values gave us 10/15 = 22/33 = 2/3; 33/100 = 1/3 (great when simple R ratios are needed); because all of those values were significantly rounded up (with 33 rounded almost 5%), it follows that also 46 should be moved up a bit to compensate for this, at the same time giving a value that's a bit nearer to 50. Further (E12, E24 etc.) numbers were used to match the spaces that were already there. –  Oct 20 '16 at 14:08
  • @vaxquis: There are a lot of cases where ratios like 2:1 and 3:2 are very useful, and given that in many cases ratios matter more than actual values, I would think that adjusting values to allow such ratios would have been helpful. – supercat Oct 20 '16 at 14:35
  • @supercat well, we have 3:2 already (15/10 & 33/22); as to 2:1 - a) note that 100/47 is only ~5% from it, b) I've seen 20 values commonly (especially with resistors), even for 10%/5% Rs (normally they should be in 0.5% E192 only) - as such, I can safely say that that adjustment was already done, long time ago. –  Oct 20 '16 at 14:42
  • @vaxquis: There are a lot of cases where an actual 2:1 ratio is really helpful; perhaps the consistency one would get by using two resistors was sufficient to justify the cost in many cases, but for something like an R/2R DAC, having to double-up half the resistors would make things much bulkier than they would be otherwise. – supercat Oct 20 '16 at 14:50
  • I like to think of it as "good enough" math as opposed to "poor math" - as a CS guy I notice my peers (and myself) tending to optimize the devil out of things that aren't necessary. Then there's real engineers out there going "Yup, it'll work. Next!" – corsiKa Nov 04 '16 at 21:52
    The selected 47 and 33 quite possibly are preferred over the calculated 46 and 32, because to get the venerable "50" you could use 47 + 3.3 = 50.3 (.6%), whereas 46 + 3.2 = 49.2 (1.6%) – P2000 Jun 25 '20 at 20:45
  • It wouldn't surprise me if it was a way of spreading out the cost of paint for the resistor colour bands by ensuring that all colours were equally used! Your theory is just as good as any other. – Andy aka Jun 25 '20 at 21:01
    jonk explains why 47 instead of 46 here. – 7h3yskr8 Apr 18 '21 at 02:22
79
Have you ever noticed the dials on a scope are always 1-2-5-10-20-50-...? This has a simple and similar reason, although the values on the dials are a bit more rounded for convenience.
Many phenomena are perceived as being logarithmic (the best known one being sound).
Look at this sequence:
\begin{array}{|c|c||c|} n & \log(n)\\ \hline 10&1.00\\ 22&1.34\\ 47&1.67\\ 100&2.00\\ 220&2.34\\ 470&2.67\\ 1000&3.00\\ \end{array}
See how nicely and evenly spaced they fit on every \$\frac{1}{3}\$ and \$\frac{2}{3}\$? You can't even see the line is slightly curved.
The practical use for this is when you want to do a quick log scale graph. Instead of trying to draw a log scale yourself you just draw a line with an evenly spaced grid like the image below and you are nearly spot-on. And the grid is nearly on octaves too, at least good enough for a quick pen and paper analysis of a circuit where things vary with 6dB/octave. With decades this number is actually closer to 20dB/decade than 18, but I'm talking orders of magnitude here. Both lines are pretty easy to draw.
The resistors/capacitors/inductors are pretty much similar. If you want an evenly divided range of resistors you can simply pick the 10-22-47 values.
See how handy these values are? They are easy to do calculations, evenly spaced and therefore commonly used. Remember that in 'the old days' computers and calculators weren't too common, so values were chosen to make things as easy as possible.
jippie
  • 33,221
  • 16
  • 95
  • 161
    @DanNeely I wish I had known that trick in physics class in school. – jippie May 03 '13 at 19:14
  • same here. Aside from one teacher who could hand place 2-9 in approximately correct places all of mine only marked powers of 10 in handdrawn graphs. – Dan Is Fiddling By Firelight May 03 '13 at 19:19
    $\log(3) \approx 0.5$, half way between 1 and 10 (hence many analog multimeters use 1-3-10-30-...). So there is your easy to place 5th tick mark (1-2-3-5-10). – jippie May 03 '13 at 19:44
  • ...and log(7) is ~ halfway between log(5) and log(10). Add a few small nudges left and right (or let us assume they were just hand drawing error), interpolate the last 3 values; and now I know how he managed to freehand a log scale. Thanks. – Dan Is Fiddling By Firelight May 03 '13 at 20:08
33
Uhm, there are lots of answers stating that power series are chosen for values, but there no answers WHY power series are chosen.
In first glance there's nothing suspicious with linear series. Let's choose simple series like 1, 2, 3, 4, 5, 6, 7, 8, 9 and 10 ohm for resistors. Ont bad. Now, expand series to 100 ohm: 11, 12... hundred of different values... thousand values for kiloohm and... million for megaohm range? Nobody will make them all. Ok. we can make them with different step for every decade: 1, 2, 3 ... 9, 10, 20, 30 ... 90, 100, 200. This seem more reasonable. Very old series had such values (capacitors were).
Let's look on a problem from another side. Fabrication process have tolerance, generally constant in units of nominal values. Say, 10 ohm resistor is actually somewhere between 9 and 11 ohm and 1000 ohm one is between 900 and 1100 (i took 10% tolerance for example). You see, there's no need to make 1001 ohm resistor, because such small difference does not make sence with such broad range.
So, it is reasonable to choose neighbour values such way, that tolerance margins will touch together: R[i]+tol% = R[i+1]-tol%. This leads us to solution to choose step proportional to nominal value (and near to twice the tolerance): say, after 100 should be 120 and after 200 should be 240, not 22. Lets build such series for example (given 5% tolerance, so every next value should be 10% greater):
             1,
1    × 1.1 = 1.1
1.1  × 1.1 = 1.21
1.21 × 1.1 ≈ 1.33
         ... 1.46
         ... 1.61
         ... 1.77
         ... 1.94
         ... 2.14
         ... 2.36
Look, we get power series very similar E24 series. Of course actual E24 is somethat aligned, first to have whole number of steps in a decade, and second to include most values already produced (thats why 3.0 and 3.3 there, not 3.2 not 3.1).
Vovanium
  • 997
The standard 10% tolerance values for resistors (very old) are
10  12  15  18  22  27  33  39  47  56  68  82
So 47 was already a choice. 10, 22, and 33 are also popular.
The standard 5% values are:
10  11  12  13  15  16  18  20  22  24  27  30
33  36  39  43  47  51  56  62  68  75  82  91
This allows 47 as well.
They are roughly logarithmic steps, see this page for more details.
Additionally a 48 is only 2% above 47. Hard to get excited about that if the part's tolerance is only 10% or 5%.
Brian Carlton
  • 13,312
  • 44
  • 65
    ... and 47 is also in the E-6 and even in the E-3 series. The latter (10, 22, 47) is even roughly similar to the series used for banknotes or coins (1 EUR, 2 EUR, 5 EUR), or oscilloscope deflection factors (100 mV/div, 200 mV/div, 500 mV/div). – zebonaut May 02 '13 at 21:08
    Any idea why some of the values are more than a full step away from the closest 1/12-decade or 1/24-decade step? For example, why 27, 33, 39, and 47, and 82 aren't 26, 32, 38, 46, and 83, respectively, since optimal values would seem to be 26.101, 31.623, 38.312, 46.416, and 82.540? – supercat May 02 '13 at 21:11
21
They are preferred numbers. They reduce the amount of values needed to be stocked.
Marko
  • 815
The number 47 is a preferred number . THE NEED for preferred numbers came to a head during WW2 for compatability of radio parts between Britain and USA . Before this there wasn't adherence to preferred values and you see all these funny numbers in prewar sets like 300 ohm 200ohm 5 ohm 160 ohm 170ohm etc .
Autistic
  • 14,616
  • 28
  • 65
