From reading some threads here I understand that the Common Mode Voltage of a Current Sensor Amplifier when measuring high-side is the average of the positive and negative input pin.
In my application I would like to measure the current in both directions. If I - as a bad example - say I select a INAx180 and look at the common mode voltage it says:
Recommended VCM: -0.2V to +26V
Absolute Maximum VCM: GND-0.3V to +26V
Am I correct to assume that I could measure a current where the positive voltage input (IN+) is greater than the negative voltage input (IN-) but would be unable to measure a current in the other direction (if it exceeds the -0.2V difference)?
