29
I have seen here and there schematics with electrolytic capacitors put on AC. This sounds weird to me.
Electrolytic capacitors have a polarity, right? If we invert the polarities on DC, bad things happen. As far as I understand, AC inverts polarity every now and then (commonly 50Hz.) Why can we put such capacitors on AC without damaging them?
Example:
schematic
From the demonstration here.
JRE
  • 71,321
  • 107
  • 188
Antoine_935
  • 1,164
  • 22
    Provide an example. – Leon Heller Apr 25 '13 at 10:45
  • Example added. http://youtu.be/qdXbnhb1bVo?t=5m57s – Antoine_935 Apr 25 '13 at 11:28
    A random video of some kid abusing capacitors is hardly a good design reference. – Dave Tweed Apr 25 '13 at 11:45
    Sure, but maybe this kid knows more than me and I'm curious to know whether this is right and why ? Sorry to ask that question, but I know basically nothing. We all started somewhere, didn't we ? – Antoine_935 Apr 25 '13 at 11:48
    @DaveTweed just because it's a bad demonstration doesn't mean there's nothing to be learned. Bad examples are still examples. – Phil Frost Apr 25 '13 at 11:51
    Antoine - he knows a little, but not enough to be considered a good guide, and he also does and says things that are at best 'not useful. Keep asking questions here and you'll know more than he does in no time :-). – Russell McMahon Apr 25 '13 at 15:00
  • Just so I'm clear, you can use an electrolytic capacitor on AC if you're using a unipolar supply, yes? – user3932000 Jul 12 '16 at 16:34
  • @DaveTweed Mike Bushroe's answer to this 7 year old question may be of interest. You, Phil, Olin and I all added reasonable comments but did not address the point made by Mike. After many (many) decades of using electrolytic capacitors I'm still not certain that they behave symmetrically enough to make his claim true. [I could have tested it 1st and looked wiser - but I haven't :-) ]. – Russell McMahon Jul 07 '20 at 21:50
6 Answers6
31
"Can" and "should" are two things. Should you do this? No: this use is outside the specified operating parameters of ordinary electrolytic capacitors. You seem to understand this already. Can you do it? Yes, as the video demonstrates. To understand why requires some understanding of what's inside the capacitor.
A capacitor is two conductors (usually plates) separated by an insulator. The more surface area, and the closer together they are, the higher the capacitance. Electrolytic capacitors have a thin film rolled up in the can. This film is covered in a thin oxide layer, and the thinness of this layer is what gives electrolytic capacitors their high capacitance relative to their size.
This oxide layer is created by the chemistry of the materials in the capacitor, and the polarity of the voltage applied to each side of the film. A voltage applied in the correct direction builds and maintains the oxide layer. If the polarity is reversed, the oxide layer dissolves.
If the oxide layer dissolves, you no longer have an insulator between the two plates of the capacitor. Instead of two plates separated by an insulator, you have two plates separated by a conductor. Instead of a device that blocks DC, you have a device that conducts it. Basically, you have a wire in a can.
Usually, when you encounter this failure mode, a large current flows, rapidly heating the internals of the capacitor. The expanding fluid and gas ruptures the safety vent or the can explodes.
Why then, does the capacitor in this example not explode?
The reverse polarity voltage is never applied for very long, and never without a correct polarity voltage applied soon after to repair whatever damage was done.
The oxide layer doesn't dissolve instantly when a reverse voltage is applied; it takes time. The time depends on the voltage applied, the size of the capacitor, the chemistry, etc, but half a cycle of 50 Hz AC is probably not long enough to cause serious damage. When the other half of the cycle comes around, the oxide layer is restored.
Any fault current is significantly limited by the series resistors.
With those resistors in series, the power available to heat the capacitor is small. There simply isn't enough power available to catastrophically destroy the capacitor because most of the available energy goes into the resistors. Perhaps you just warm the capacitor slightly. When the voltage reverses direction, the oxide layer can reform.
Probably you still damage the capacitor eventually, to some extent, but it is operational enough for the demonstration.
Phil Frost
  • 57,310
  • 18
  • 145
  • 267
Most likely you are not noticing that the capacitor has a DC bias and that the lowest peaks of the voltage accross it don't go negative.
In the only example you provided, there is a LED in the circuit. Remember that a LED is also a diode. When he put the capacitor in series with the LED, it should have prevented significant reverse voltage accross the capacitor. When the capacitor was put parallel to the LED, the LED would have shunted anything more than a couple of volts reverse polarity around the capacitor.
More importantly however, this was just some video from some guy on the internet doing a demo and not trying to be rigorous. He may well have been aware the capacitor was being abused somewhat and didn't care. We also don't know whether the capacitor eventually suffered some damage.
So in summary, the reasons you are seeing electrolytic capacitors apparenly being reverse voltaged are:
  1. They aren't. There is a DC bias that you didn't notice.
  2. They are, and maybe getting damaged, but whoever is doing it doesn't realize this or doesn't care.
  3. You can't believe everything you see on the internet.
Olin Lathrop
  • 313,258
  • 36
  • 434
  • 925
    I didn't notice any DC bias in the linked video; did you? – Phil Frost Apr 25 '13 at 12:25
  • @Phil: As I said, the video had a LED in the circuit, which acts as a diode. – Olin Lathrop Apr 25 '13 at 13:00
    two LEDs: http://www.youtube.com/watch?v=qdXbnhb1bVo&feature=youtu.be&t=6m26s – Phil Frost Apr 25 '13 at 13:04
    The fact that both LEDs were flickering means that a negative voltage was sometimes over the capacitor. With a DC bias, only one of them would flicker (unless they were common-cathode, but then why have two of them?). The explanation from @PhilFrost seems to make sense. Probably would have busted the capacitor with a higher AC voltage or at lower frequency. – HackerBoss Jul 17 '19 at 05:34
There are a couple of possible answers.
The most common application of electrolytics in AC applications is as coupling capacitors in AC amplifiers. In this case, there is usually a clear DC bias across the capacitor (as a result of how the individual amplifier stages are biased), so even though it's passing an AC current, the voltage across the capacitor itself never actually reverses.
Second, there is such a thing as a non-polarized electrolytic capacitor that is sometimes used in powerline-frequency applications. It has oxide layers on both plates.
Dave Tweed
  • 172,781
  • 17
  • 234
  • 402
In the video clip included we do not know the output voltage of the transformer, the type of LEDs used, the resistance values of the two resistors, or the ratings of the electrolytic capacitor being tested. Freeze framing and contrast expanding it looks like the cap is rated for 35V, is clearly polarized, and might have a capacitance of 200uF.
The LEDs appear to be common, small, red LEDs which typically have a forward current of 20mA. Even freeze framing it is difficult to read the values of the resistors and there is no way to read the transformer output RMS voltage. But assuming that the resistors were chosen to produce the proper 20mA current for the LEDs, and that the LEDs are wired parallel, reversed so that current can flow in each direction it is possible to build a spice model to approximate what the video clip's circuit might have been.
Assuming the total series resistance of the two resistors (can be modeled as a single, series resistor) of 200 ohms and the transformer 5V peak to ground we get a current of 18mA. If the capacitor really is 200uF, then a 50hz waveform with a peak of +/- 18mA is not capable of fully charging the cap. 50hz is 20msec for a complete cycle, 1msec for each positive or negative half cycle.
Each 10msec negative going half cycle is less than 1/4 of the RC time constant. Using a forward parallel (leakage) resistance typical for a 200uF cap of 2K ohms, and adding a reverse parallel resistance that is much worse of 250 ohms using an ideal diode and resistor in parallel with the cap shows why there was no damage when running a DC cap in an AC circuit. The peak positive capacitor voltage in the simulation was only 280mV, while the reverse voltage peak with the greater leakage current only 180mV.
With the negative voltage peaking at less than 1% of its rated forward voltage the oxide layer was never in any danger. When the capacitor was hooked up in parallel with the LEDs the voltage across the capacitor never got high enough to allow the LEDs to work, and unlike the series configuration, there was no charge/discharge current going through them. With the current limiting resistors still in series with the capacitor it was not able to charge up to dangerous levels, especially when reverse biased.
If the LEDs had been given a separate series resistor to limit their current and the capacitor in series with a much smaller resistance such that the 50hz half cycle time was several RC time constants long, then the capacitor would have reached nearly full negative voltage and probably fail very quickly. But limited to the LED safe current it could not begin to charge up before the voltage reversed and so was not in any danger.
Voltage Spike
  • 82,181
  • 41
  • 84
  • 220
Mike Bushroe
  • 106
  • Mike - welcome to SE EE. Thanks for the useful comments. It would be interesting to see if the real world circuit acts as symmetrically as you suggest and so stays at very low voltage across the capacitor. (Presumably yes). | I've removed my now redundant version of your answer. Note how Voltage Spike has formated your answer by adding a few breaks. This helps the general feeling of readability even when the material is closely related between paragraphs. – Russell McMahon Jul 07 '20 at 21:45
Why can I put an electrolytic capacitor on AC?
You can but it will damage the capacitor, possible fatally, except in trivial cases.
The example shown does not prove much at all.
If you apply a modest reverse voltage to a capacitor compared to its voltage rating it may not do too much damage if not too much current flows and if not done for too long.
Small amounts of damage done in such cases may not be apparent.
For excessive values of modest, too much, too much and too long the capacitor may let you know in various interesting ways such as blowing all its insides out through the base seal, or through the safety vent formed by the cross shaped grooves on the top or just by boiling or drying out or refusing to come to the party in future.
One way in which electrolytic capacitors can be used in an AC circuit is to put two in series polarity-opposed. Each capacitor will tend to "deal with" the appropriate part of the waveform. The reverse biased capacitor will pass much current at low reverse voltage and use the other half to block forward voltage DC. In this case the "too much" limits are not reached.
Russell McMahon
  • 150,303
  • 18
  • 213
  • 391
Go outside and pull the service cover off of your AC condensing unit. There you will find bipolar electrolytic caps on the compressor and fan motors. Sometimes there are 2 different value caps in the same package.
