Where did you find this circuit? It won't do anything useful; any voltage significantly less than Vdd on the input will just short out Vdd.
– HearthApr 06 '23 at 14:33
The PNP is wrongly connected, and the circuit is not helpful in anything, besides testing the reverse Vbe breakdown voltage. I suggest reading again some basic text on bipolar transistors.
– LuCApr 06 '23 at 14:36
@lub2354 It still does the same thing I said in the first place, just with the transistor in forward active instead of reverse active mode.
– HearthApr 06 '23 at 15:27
Hello, I have built the circuit attached bellow.My goal is to switch it into saturated state.
for forward active PNP we need the Emitter-base forward biased and base-collector reversed biased.
(emitter)P-N(base) needs to be V_E>V_B to forward biased.
(base)N-P(collector) reversed biased V_base>V_collector.
I think its in active state.How do i improve my circuit co i could switch it between saturation and active?
Thanks.
I think its in active state.How do i improve my circuit co i could switch it between saturation and active? Thanks.
https://pdf1.alldatasheet.com/datasheet-pdf/view/11478/ONSEMI/2N5087.html
https://ibb.co/0DpWMFM
– lub2354 Apr 07 '23 at 15:57
