12
As far as I know, BJTs are better than MOSFETs at high frequencies (for example "hard" PWM) because MOSFETs have larger parasitic capacitances (Ciss/Cgs), is this correct?
If that's the case, why do people use MOSFETs for PWM and not BJTs?
JRE
  • 71,321
  • 107
  • 188
Cblue X
  • 273
    what frequency is the PWM? – jsotola Mar 27 '23 at 19:26
    Probably because DC losses are lower with MOSFET devices. Power MOSFETs are available with ON resistances in the low milliohms, or lower region. Overall it comes down to which device has the lowest overall losses (switching & DC), which affect power supply efficiency. – SteveSh Mar 27 '23 at 19:26
    i tried to build a BJT PWM once and it came out slower because the transistor took a long time to recover from saturation. So it could turn on fast but was slow to turn off – tobalt Mar 27 '23 at 19:28
  • @tobalt even with a Baker diode? – Sredni Vashtar Mar 27 '23 at 19:44
    Sometimes PWM is done with IGBTs. – Theodore Mar 27 '23 at 19:49
  • Thanks for your answers and your help!, i have heard before @tobalt than bjts are slower to turn off, but i didnt rembered it ! – Cblue X Mar 27 '23 at 21:02
  • @SredniVashtar Using a Baker clamp prevents saturation, which increases the collector-emitter on voltage. It does mean you can switch off faster, but it increases conduction losses. – Hearth Mar 28 '23 at 01:49
Why do people use MOSFETs for PWM and not BJTs?
Mostly because driving BJTs is a relative pain in spite of their lower input capacitance. They are current controlled devices, not voltage controlled, and they take a lot of current. Even small switching power supplies that fit in one's hand switch tens of amperes like it was nothing much. So that's what would need to be done with BJTs.
Low voltage MOSFETs can have quite reasonably driveable gate capacitances. The gate drivers have to push 10s of amperes into the gate, but only for a very short time, on the order of nanoseconds or tens of. Even at 1MHz switching frequency, that's only a couple % of time spent switching. The rest is quiescent: no gate current flowing, no attendant dissipation from the drive circuit.
Now, to minimize losses, BJTs have to switch hard, so they'll be operating with small V(CE), and their current gain may well suffer for it. A "small" V(CE) for a BJT is still an order of magnitude or two larger than that of a MOSFET in a low-voltage power application. So, those BJTs generate a lot of heat just from conduction loss. They may switch "faster" ultimately, but the losses they incur from having to be driven all the time are quite enormous.
A switch that has to push 30A peak may need a couple amperes of base drive when it is on, not only during switching events. Iif that base drive can't flow into the output or into an additional inductor to be recuperated, it's additional loss. While the base current is flowing, it's flowing through the base-emitter junction - that's up to 1V of voltage drop for the base current to make heat on.
The base charge needed to go into saturation needs to be controlled, often in closed loop, so that not too much energy is wasted when turning the switch off, having to desaturate it - but there must be enough charge to saturate the switch.
BJTs make better low power RF amplifiers than MOSFETs, but that's not how the majority of discrete MOSFETs out there are used. Pretty much all discrete power MOSFETs are used in switching power supplies and power conversion in general (e.g. chargers,) with a chunk left over for motor drives. The other applications are comparably a rounding error on the global scale AFAIK.
Switching supplies in the late 70s through late 80s did use BJTs as switching elements. They were designed to work reasonably well, but the engineers designing would have sold their souls for modern power MOSFETs, if that was made available as an alternative to them. Anyone competent back then could whip what passes for a gate driver on the back of a napkin. So they'd have been more than happy to generate those current pulses to get the MOSFET switches switching.
Finally: For hard small-signal voltage switching, BJTs sort of suck without either Schottky clamps or gold doping to vastly reduce the stored charge. Try building digital logic out of discrete small signal BJTs - even RF types - vs discrete small signal MOSFETs. The BJTs are slow as molasses compared to MOSFETs in that application. They will stay fast as long as the stored charge doesn't accumulate, so switching them at 50% duty cycle and quickly will give appearances of good performance - but past that point it'd be like hitting freshly laid hot asphalt.
To make BJTs fast - faster than MOSFETs - they need to switch currents, not voltages. That means ECL logic. A heating element that incidentally also computes. Now, don't get me wrong, ECL is quite an amazing logic family, but if, for whatever reason, I was asked to build discrete logic for a demonstration, I'd always go with CMOS from discrete parts. It's pretty much foolproof and if you don't make logic mistakes, it'll pretty much work on first try. BJTs will be much harder unless you prototype first, or copy an established logic family like TTL.
JRE
  • 71,321
  • 107
  • 188
    Thanks! i really appreciate this answer! – Cblue X Mar 27 '23 at 23:14
    One nit: BJTs are voltage activated: the base voltage, not the current, controls the injection current from the emitter. The base current is parasitic: not fundamentally necessary. So, MOSFETs have parasitic charge that the driver must supply, BJTs have parasitic current that the driver must supply. – John Doty Mar 28 '23 at 12:55
    That was awesome. I know we're not supposed to write thanks in the comments, but thanks. – Simon Fitch Mar 28 '23 at 14:47
    @JohnDoty maybe that is the physicist perspective but I'm fairly sure most engineers will go for Ib*hFE – user253751 Mar 28 '23 at 15:11
    @user253751 You should read Horowitz and Hill's "The Art of Electronics". – John Doty Mar 28 '23 at 15:28
    @JohnDoty That's actually a very good point and I'll revise the answer later. I fully agree. It's just that with BJTs that current is a big design driver, and the voltage aspect in relative isolation is mainly useful in "closely coupled" pairs/multiples like differential pairs, current sources, bandgaps, and such. I wonder if there's any way to make small signal IGBTs that would perform similarly to small signal BJTs but with less concern about base current. – Kuba hasn't forgotten Monica Mar 28 '23 at 18:21
    @John Doty: It depends on the model you use. In some regions, a current-controlled current source (CCCS?) is appropriate. It is a complex nonlinear device. – Peter Mortensen Mar 29 '23 at 17:32
  • @PeterMortensen Not that complicated, and very predictable, as a voltage activated device. The collector current and temperature tell you the transconductance fairly precisely, don't even need a datasheet. But β is a very sloppy, poorly controlled parameter. – John Doty Mar 29 '23 at 18:02
    @JohnDoty this is routinely brought up. But the BJT can be considered either way. See the reference list in my answer to this question https://electronics.stackexchange.com/questions/547625/working-of-bipolar-junction-transistor-with-electron-flow – Sredni Vashtar Mar 29 '23 at 21:39
10
Be careful you do not mistake analog bandwidth vs digital switching speed. When you say or hear "BJTs are better at high frequencies", what is often being referred to is bandwidth as an amplifier for analog signals which (apparently) is not the same as digital switching speed. The issue seems to be quite complex as far as the switching speed and bandwidth comparison between MOSFETs and BJTs and what I said just now is as close as an answer as I have ever gotten.
But there are other considerations for PWM other than frequency and these are much easier to understand.
The first advantage of MOSFETs is that the gate drive currents do not need to scale with the source-drain currents. With BJTs, if you want to pass a lot of collector-emitter current, you need to increase the base current which can be problematic.
The second advantage of MOSFETs is that "low voltage" devices, the source-drain resistance is low enough to best BJTs, which have a fairly fixed collector-emitter voltage drop at saturation, in conduction losses.
However, as you increase the voltage rating of devices, the source-drain resistance of MOSFETs increase and the balance between tradeoffs for different types of transistors begins to change. At sufficiently high voltage ratings, the fixed collector-emitter voltage drop of BJTs results in lower conduction losses than MOSFETs.
This is the reason IGBTs exist. They try to combine the lower conduction loss of BJTs at higher voltages with the easier drive of MOSFETs.
DKNguyen
  • 56,670
  • 69
  • 160
    Also BJTs are minority-carrier devices, and the storage time can make turn-off much slower than a FET. Though as you point out, as voltage rises, the die size of FETs increases rapidly and at some point an IGBT will have a cost advantage over a FET, but wide bandgap GaN and SiC FETs make high voltage and high switching speed practical. – John D Mar 27 '23 at 20:14
  • @JohnD Yeah. It really all comes down to technological capability. – DKNguyen Mar 27 '23 at 20:16
  • Thanks @DKNguyen really helpful answer! – Cblue X Mar 27 '23 at 23:21
  • So @JohnD you are telling me that bjts can turn on faster than MOSFET's but they have different turn on/turn off times? and whit a MOSFET i can have equal (or almost equal) turn on /turn off time? – Cblue X Mar 27 '23 at 23:23
    @CblueX It could be the that the BJT traverses within the region where it acts as an amplifier faster than a MOSFET, but takes longer to recover once in the full conduction region which is what you are operating in as a switch. I didn't use terms like saturation or linear region because they have different meanings between the two transistor types so no one ever knows if anyone else is using the term properly or improperly and it's really troublesome to use the terms when talking about the two simultaneously. – DKNguyen Mar 27 '23 at 23:44
  • @CblueX I am aware of a method of BJT switching called quasi-saturation (saturation = full conduction for a BJT...means something else for a MOSFET) where you do not quite go into full conduction and instead remain on the border between amplifier and switch so that you can switch faster, at the expense of conduction efficiency. – DKNguyen Mar 27 '23 at 23:46
    Addition: The difference between "analog bandwidth" and "digital switching speed" is that analog bandwidth is the fastest small input wiggle that can make a bigger output wiggle, while digital switching means turning the transistor all the way on or off, from one extreme to the other, not just a little wiggle – user253751 Mar 28 '23 at 08:16
  • Somebody should also mention temperature coefficients. – edmz Mar 28 '23 at 15:28
  • @CblueX I didn't say that BJTs can turn on faster than MOSFETs. To be able to make that comparison you would have to set the parameters for the comparison. A BJT and MOSFET of the same die size? What process is the MOSFET? Or a BJT and MOSFET for the same application performance, where the MOSFET die size may be smaller? Or may not depending on the voltage and requirements. Or are we talking about a BJT vs. a MOSFET in an integrated circuit? A blanket statement is hard to make. – John D Mar 28 '23 at 15:36
The BJT is harder to drive than the MOSFET or IGBT. High current high voltage devices can have a current gain of less than 10. More complex circuitry, like a proportional base drive drive or Baker clamps, to keep the BJT out of saturation is needed to keep switching losses reasonable even at 20 kHz.
When this is done, the switching losses are still more than the MOSFET and the onstate voltage drop is higher leading to more conduction losses. In earlier decades the RDS,on of the MOSFET was much higher and the MOSFETs were much more expensive so BJTs were used.
These days the only really expensive MOSFETs are the high voltage, low resistance ones. IGBTs which are slow and cheap and easy to drive are used here.
Autistic
  • 14,616
  • 28
  • 65
  • What is a "prop drive"? Do you have a reference? – Peter Mortensen Mar 29 '23 at 17:22
  • @ Peter Mortensen .Prop drive is short form for proportional base drive .In the day it was implemented with a current transformer with 1 turn on the collector and say 7 turns on the base .The number 7 is just a number representing a low gain HV BJT . – Autistic Mar 30 '23 at 06:21
