I'm charging a 3.7V li-ion with a TP4056. The load (approximately 20mA) is connected in parallel with the li-ion. If I disconnect the battery while the TP4056 is receiving 5V on its input, I hear a buzzing sound. Once I reconnect the battery it dissappears.
Any idea what this could be?
MP2315 is stepping down a 12V battery to 5V. I also tried disconnecting R1 from 5V and injecting 5V from my RD6006. Same buzzing. Output with no battery: 40mVAC (an buzzes a lot), 1 battery: 60mVAC (still some buzzing), 2 batteries: 2.5mVAC (next to no buzz). Load is always 20mA (MCU + other things). Seems the TP4056 is more happy with more load. Scope of BAT+ at various battery loads is attached. Strangely enough, the 2 batteries have some bad spikes here and there, but less audible noisy. (The frequencies measured on the scope varies greatly from shot to shot.)
No battery:
1 battery:
2 batteries:
https://electronics.stackexchange.com/questions/411283/tp4056-and-li-ion-battery-charging-that-never-ends
The battery will never be removed. Sleep, charge enable, etc will be software controlled. But I'm trying to simulate what happens when the battery life is completely worn out, ie. won't accept charge. In that case, the battery will be equivalent to a very tiny load (and that's when the buzzing starts). The audible buzzing doesn't worry me, but I am concerned it's not good in the long run (battery or ic).
– okwestern Mar 13 '23 at 18:46
