What makes an InGaAs detector more sensitive to infrared light than visible light, considering that visible light has a higher photon energy?
JRE
  • 71,321
  • 107
  • 188
Kicr
  • 59
    why do you say that an IR camera cannot detect visible light? – jsotola Feb 25 '23 at 07:10
  • @jsotola, thanks for the comments. Check this link https://pdf.directindustry.com/pdf/xenics/bobcat-320-series/54398-666413.html, the QE is extremely low in the VIS range. – Kicr Feb 25 '23 at 07:13
    that is a specific camera ... your question asks about IR cameras in general ... your question should really be about the sensor that is used in that camera – jsotola Feb 25 '23 at 07:16
    cameras like that are often provided with filters in the optical path to attenuate visible light – Neil_UK Feb 25 '23 at 07:20
    That's an ingaas sensor rather than a more common silicon sensor. Silicon can detect visible and NIR less than about 1000nm. InGaAs goes much further into the IR but doesn't absorb visible very efficiently. If you're really asking what makes a semiconductor sensitive to lower energy photons but not higher, you should edit your question to make that clear. – user1850479 Feb 25 '23 at 15:14
