I have a 18 V 1.5 A battery. But when I test the output it shows 21 V. Could I use this on a 19 V 1.5 A router as backup (UPS) Tx. Input on the device shows 19.5 V if I test it.
winny
  • 14,707
  • 46
  • 66
The voltage of a battery ranges about +/- 10%1 around the so-called nominal value (the value that it has written on), depending on the load level. Particularly if you have a fully charged battery and you're measuring it using a voltage meter, which doesn't impose any load on the battery, it will show significantly higher than the nominal value.
Whether you can use this battery for your backup will depend on what electronics you use to control its charge/discharge current. You typically can't replace a voltage-regulated PSU with a battery, just because the voltage of a battery is not constant. You need some kind of charge controller (or a real UPS to attach the battery to).
1The exact voltage that defines a full or empty battery depends on the chemistry and other factors of the battery used.
Neil_UK
  • 166,079
  • 185
  • 408
PMF
  • 672
  • 14
