Is it possible to somehow eliminate or reduce the TL431 constant-current source voltage drop?
I have studied this application note from TI. In my opinion, it nicely presents the possibilities of using the TL431, especially in relation to the current limitation.
Not much is mentioned here about the disadvantages of the voltage drop. The transistor in the picture drops the voltage by the threshold voltage - approximately 0.5 V. This causes a problem when, after current limiting, I supply current to the IC that needs it without any loss. I tested it with the following configuration:
- Vin = 6 V
- Iout = limited to 20 mA
- Rs = 100 Ω
- R1 = 2200 Ω
- Transistor 2N2222
- Voltage drop 0.5 V
Would it be possible to replace the transistor with an N-type MOSFET and get rid of the drop? I have understood that a voltage-controlled MOSFET might work here. Does anyone have experience with this?
The problem with MOSFETs in these circuits can of course be ringing. Is it possible to reduce it if it causes a problem?
