When I am trying to adjusts the charging resistor also it doesn't give the output. The output comes like 1.8 V only.
NOTE: I have not connected any load.
ocrdu
  • 9,195
  • 22
  • 32
  • 42
  • Please edit your question to show the circuit you are using, the supply voltage and a link to the datasheet. Welcome to EE.SE. – Transistor Nov 25 '22 at 07:28
  • If you are using TP4056 module, check for short circuits on it, maybe that's the case. Any additional information (module you using, input signals) will be appreciated. – MakePlatanGreatAgain Nov 25 '22 at 07:27
The TP4056 is a Li-ion battery charging IC. It does not produce a constant voltage output without a suitable battery connected e.g. it produces a limited "trickle charge" current (not constant voltage) when a low battery voltage is detected (see the datasheet). Without any battery connected, I expect a low battery voltage (actually none) is being detected.
When you connect a suitable battery, you should see the expected CC/CV charging functionality.
SamGibson
  • 17,870
  • 40
  • 59
