-4
I got these errors. What should I do?
Circuit: * C:\Users\hp\Documents\LTspiceXVII\EKG Schaltung.asc
Error on line 10 : c3 n002 n009 470 pf Unknown parameter "pf" Error on line 13 : c1 n005 n004 3.3 mu Unknown parameter "mu" WARNING: Less than two connections to node NC_01. This node is used by V1. WARNING: Less than two connections to node NC_02. This node is used by V2. Direct Newton iteration for .op point succeeded. Ignoring empty pin current: Ix(u3:1) Ignoring empty pin current: Ix(u3:2) Ignoring empty pin current: Ix(u4:1) Ignoring empty pin current: Ix(u4:2) Ignoring empty pin current: Ix(lm324:1) Ignoring empty pin current: Ix(lm324:2) Ignoring empty pin current: Ix(u1:1) Ignoring empty pin current: Ix(u1:2) Ignoring empty pin current: Ix(u3:1) Ignoring empty pin current: Ix(u3:2) Ignoring empty pin current: Ix(u4:1) Ignoring empty pin current: Ix(u4:2) Ignoring empty pin current: Ix(lm324:1) Ignoring empty pin current: Ix(lm324:2) Ignoring empty pin current: Ix(u1:1) Ignoring empty pin current: Ix(u1:2) Heightened Def Con from 1.01564e-006 to 1.01877e-006 Heightened Def Con from 1.02352e-006 to 1.02752e-006 Heightened Def Con from 1.02898e-006 to 1.03011e-006 Heightened Def Con from 1.03275e-006 to 1.03675e-006 Heightened Def Con from 1.04004e-006 to 1.04216e-006 Heightened Def Con from 1.04346e-006 to 1.04646e-006 Heightened Def Con from 1.04775e-006 to 1.05175e-006 Heightened Def Con from 1.05866e-006 to 1.06066e-006 Heightened Def Con from 1.06155e-006 to 1.06555e-006 Heightened Def Con from 1.0693e-006 to 1.0733e-006 Heightened Def Con from 1.08894e-006 to 1.09194e-006 Heightened Def Con from 1.11181e-006 to 1.11581e-006 Heightened Def Con from 1.18035e-006 to 1.18435e-006 Heightened Def Con from 1.36509e-006 to 1.36909e-006 Heightened Def Con from 1.52071e-006 to 1.52271e-006 Heightened Def Con from 2.0028e-006 to 2.0098e-006 Heightened Def Con from 2.28336e-006 to 2.28736e-006 Heightened Def Con from 3.52574e-006 to 3.52786e-006 Heightened Def Con from 3.55417e-006 to 3.55817e-006 Heightened Def Con from 4.01314e-006 to 4.01714e-006 Heightened Def Con from 4.64992e-006 to 4.65392e-006 Heightened Def Con from 8.35414e-006 to 8.35452e-006 Heightened Def Con from 2.24585e-005 to 2.24615e-005 Heightened Def Con from 2.72313e-005 to 2.72334e-005 Heightened Def Con from 2.72977e-005 to 2.73017e-005 Heightened Def Con from 2.7317e-005 to 2.7321e-005 Heightened Def Con from 2.7325e-005 to 2.7329e-005 Heightened Def Con from 2.73299e-005 to 2.73329e-005 Heightened Def Con from 2.73343e-005 to 2.73383e-005 Heightened Def Con from 2.73509e-005 to 2.73549e-005 Heightened Def Con from 2.74325e-005 to 2.74365e-005 Heightened Def Con from 2.74548e-005 to 2.74578e-005 Heightened Def Con from 2.74949e-005 to 2.74989e-005 Heightened Def Con from 2.75094e-005 to 2.75134e-005 Heightened Def Con from 2.7772e-005 to 2.77742e-005 Heightened Def Con from 2.77995e-005 to 2.78035e-005 Heightened Def Con from 2.78114e-005 to 2.78115e-005 Heightened Def Con from 2.78116e-005 to 2.78127e-005 Heightened Def Con from 2.78136e-005 to 2.78157e-005 Heightened Def Con from 2.78159e-005 to 2.78159e-005 Heightened Def Con from 2.7816e-005 to 2.7817e-005 Heightened Def Con from 2.7817e-005 to 2.78171e-005 Heightened Def Con from 2.78171e-005 to 2.78201e-005 Heightened Def Con from 2.78328e-005 to 2.78348e-005 Heightened Def Con from 2.7835e-005 to 2.7838e-005 Heightened Def Con from 2.7845e-005 to 2.7847e-005 Heightened Def Con from 2.78487e-005 to 2.78497e-005 Heightened Def Con from 2.78497e-005 to 2.785e-005 Heightened Def Con from 2.78502e-005 to 2.78522e-005 Heightened Def Con from 2.78524e-005 to 2.78526e-005 Heightened Def Con from 2.78526e-005 to 2.78556e-005 Heightened Def Con from 2.78559e-005 to 2.7856e-005 Heightened Def Con from 2.78561e-005 to 2.78591e-005 Heightened Def Con from 2.78606e-005 to 2.78609e-005 Heightened Def Con from 2.7861e-005 to 2.7863e-005 Heightened Def Con from 2.78704e-005 to 2.78706e-005 Heightened Def Con from 2.78709e-005 to 2.78729e-005 Heightened Def Con from 2.78885e-005 to 2.78905e-005 Heightened Def Con from 2.79844e-005 to 2.79874e-005 Heightened Def Con from 2.80593e-005 to 2.80613e-005 Heightened Def Con from 2.80726e-005 to 2.80727e-005 Heightened Def Con from 2.80727e-005 to 2.80747e-005 Heightened Def Con from 2.80758e-005 to 2.80759e-005 Heightened Def Con from 2.8076e-005 to 2.80761e-005 Heightened Def Con from 2.80761e-005 to 2.80765e-005 Heightened Def Con from 2.80774e-005 to 2.80774e-005 Heightened Def Con from 2.80775e-005 to 2.80786e-005 Heightened Def Con from 2.80787e-005 to 2.80807e-005 Heightened Def Con from 2.80807e-005 to 2.80808e-005 Heightened Def Con from 2.80809e-005 to 2.80811e-005 Heightened Def Con from 2.80826e-005 to 2.80828e-005 Heightened Def Con from 2.80828e-005 to 2.80849e-005 Heightened Def Con from 2.80864e-005 to 2.80874e-005 Heightened Def Con from 2.80875e-005 to 2.80885e-005 Heightened Def Con from 2.80885e-005 to 2.80885e-005 Heightened Def Con from 2.80886e-005 to 2.80886e-005 Heightened Def Con from 2.80886e-005 to 2.80896e-005 Heightened Def Con from 2.80896e-005 to 2.80916e-005 Heightened Def Con from 2.80949e-005 to 2.80969e-005 Heightened Def Con from 2.80974e-005 to 2.80975e-005 Heightened Def Con from 2.80975e-005 to 2.80987e-005 Heightened Def Con from 2.80998e-005 to 2.80999e-005 Heightened Def Con from 2.80999e-005 to 2.81019e-005 Heightened Def Con from 2.81034e-005 to 2.81034e-005 Heightened Def Con from 2.81034e-005 to 2.81054e-005 Heightened Def Con from 2.81059e-005 to 2.81089e-005 Heightened Def Con from 2.81094e-005 to 2.81116e-005 Heightened Def Con from 2.81119e-005 to 2.8112e-005 Heightened Def Con from 2.8112e-005 to 2.8114e-005 Heightened Def Con from 2.81154e-005 to 2.81154e-005 Heightened Def Con from 2.81154e-005 to 2.81166e-005 Heightened Def Con from 2.81172e-005 to 2.81173e-005 Heightened Def Con from 2.81173e-005 to 2.81173e-005 Heightened Def Con from 2.81173e-005 to 2.81176e-005 Heightened Def Con from 2.81176e-005 to 2.81186e-005 Heightened Def Con from 2.81186e-005 to 2.81206e-005 Heightened Def Con from 2.81209e-005 to 2.8121e-005 Heightened Def Con from 2.81213e-005 to 2.81233e-005 Heightened Def Con from 2.81237e-005 to 2.81239e-005 Heightened Def Con from 2.81239e-005 to 2.81259e-005 Heightened Def Con from 2.81307e-005 to 2.81318e-005 Heightened Def Con from 2.81318e-005 to 2.8133e-005 Heightened Def Con from 2.8137e-005 to 2.8137e-005 Heightened Def Con from 2.8137e-005 to 2.8139e-005 Heightened Def Con from 2.81411e-005 to 2.81433e-005 Heightened Def Con from 2.81434e-005 to 2.81435e-005 Heightened Def Con from 2.81435e-005 to 2.81445e-005 Heightened Def Con from 2.81445e-005 to 2.81448e-005 Heightened Def Con from 2.81448e-005 to 2.81458e-005 Heightened Def Con from 2.81458e-005 to 2.81469e-005 Heightened Def Con from 2.81469e-005 to 2.8147e-005 Heightened Def Con from 2.81471e-005 to 2.81472e-005 Heightened Def Con from 2.81472e-005 to 2.81483e-005 Heightened Def Con from 2.81483e-005 to 2.81486e-005 Heightened Def Con from 2.81488e-005 to 2.81489e-005 Heightened Def Con from 2.81489e-005 to 2.81501e-005 Heightened Def Con from 2.81518e-005 to 2.81538e-005 Heightened Def Con from 2.81541e-005 to 2.81543e-005 Heightened Def Con from 2.81544e-005 to 2.81544e-005 Heightened Def Con from 2.81544e-005 to 2.81556e-005 Heightened Def Con from 2.81556e-005 to 2.81556e-005 Heightened Def Con from 2.81556e-005 to 2.81556e-005 Heightened Def Con from 2.81556e-005 to 2.81556e-005 Heightened Def Con from 2.81556e-005 to 2.81556e-005 Heightened Def Con from 2.81556e-005 to 2.81576e-005 Heightened Def Con from 2.81576e-005 to 2.81596e-005 Heightened Def Con from 2.81597e-005 to 2.816e-005 Heightened Def Con from 2.816e-005 to 2.8162e-005 Heightened Def Con from 2.81625e-005 to 2.81646e-005 Heightened Def Con from 2.81676e-005 to 2.81698e-005 Heightened Def Con from 2.81703e-005 to 2.81705e-005 Heightened Def Con from 2.81705e-005 to 2.81708e-005 Heightened Def Con from 2.81709e-005 to 2.81739e-005 Heightened Def Con from 2.81803e-005 to 2.81805e-005 Heightened Def Con from 2.8181e-005 to 2.8183e-005 Heightened Def Con from 2.81832e-005 to 2.81852e-005 Heightened Def Con from 2.81861e-005 to 2.81873e-005 Heightened Def Con from 2.81953e-005 to 2.81973e-005 Heightened Def Con from 2.82009e-005 to 2.82039e-005 Heightened Def Con from 2.82048e-005 to 2.82068e-005 Heightened Def Con from 2.82195e-005 to 2.82197e-005 Heightened Def Con from 2.82199e-005 to 2.822e-005 Heightened Def Con from 2.822e-005 to 2.82204e-005 Heightened Def Con from 2.82208e-005 to 2.82228e-005 Heightened Def Con from 2.82228e-005 to 2.8223e-005 Heightened Def Con from 2.8223e-005 to 2.8226e-005 Heightened Def Con from 2.82322e-005 to 2.82325e-005 Heightened Def Con from 2.82333e-005 to 2.82335e-005 Heightened Def Con from 2.82343e-005 to 2.82354e-005 Heightened Def Con from 2.82356e-005 to 2.82396e-005 Heightened Def Con from 2.82413e-005 to 2.82423e-005 Heightened Def Con from 2.82423e-005 to 2.82444e-005 Heightened Def Con from 2.82452e-005 to 2.82462e-005 Heightened Def Con from 2.82465e-005 to 2.82467e-005 Heightened Def Con from 2.82467e-005 to 2.82468e-005 Heightened Def Con from 2.82468e-005 to 2.82468e-005 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 10.5896 to 10.5896 Heightened Def Con from 11.0569 to 11.0569 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256 Heightened Def Con from 13.5256 to 13.5256
Date: Mon Nov 21 13:07:12 2022 Total elapsed time: 663.346 seconds.
tnom = 27 temp = 27 method = modified trap totiter = 27705240 traniter = 27705208 tranpoints = 4930144 accept = 3398982 rejected = 1531378 matrix size = 95 fillins = 146 solver = Normal Thread vector: 17.8/5.8[4] 4.8/3.4[4] 4.1/3.9[1] 0.8/3.2[1] 2592/500 Matrix Compiler1: 12.38 KB object code size 3.5/2.2/[1.1] Matrix Compiler2: 8.99 KB object code size 1.6/1.9/[0.8]
winny
  • 14,707
  • 46
  • 66
Maya
  • 23
    Begin by fixing your errors (470 pF -> 470p, 3.3 mu -> 3.3m) and by connecting the negatives of V1 and V2 to ground. – Renan Nov 21 '22 at 12:18
    I’m voting to close this question because I’m voting to close this question because asking for what is essentially an LTSpice tutorial is not an on-topic question. – brhans Nov 21 '22 at 17:46
  • Also similar question(s) posted by the OP but suggestions were ignored. https://electronics.stackexchange.com/questions/643334/i-dont-know-what-to-do-to-get-a-sine-in-this-ltspice-circuit – PStechPaul Nov 21 '22 at 19:28
  1. Your capacitor values are incorrectly specified (you need to write 470p and 3.3u rather than 470 pf and 3.3 mu)
  2. The negative terminals of V1 and V2 aren't connected to anything.
Renan
  • 5,120
  • 28
  • 45
Your capacitor values are malformed: You have to remove the space in "470 pF" (otherwise it gets interpreted as multiple parameters, and ideally you just write "470p"), and use "µ" or "u" instead of "mu".
Jonathan S.
  • 18,288
  • 34
  • 56
