Something that might help, at least conceptually, is you can divide the inductor into the superposition of the air-core coil, plus the contribution due to the permeable core.  Thus, roughly speaking, the spread-out coil is similar to a solenoid of much longer aspect ratio but the same turns (but not a solenoid, rather, one bent around into a toroidal helix), while the scrunched-up one resembles a short solenoid (with almost no bend, as it happens; well, perhaps, anyway!).
Then, when you add in the core's contribution, clearly it'll be more, but in a (1 + μx) sort of way, with x being some geometry factor, and μ the relative permeability.  Clearly, that factor will be close to 1 for the evenly-distributed case, though how much less than 1 in the scrunched case, who knows.
This doesn't actually help analytically, as the coil itself is now massively harder to solve (it doesn't even have the axial symmetry of a helix to help out*), and the core at low μ isn't following any nice rules either (flux is hardly contained within the ring, leakage is comparable).  This is basically the domain of, either shove it into FEM, build and measure it yourself, or pray to Thoth that someone's already done all the hard work for you and you can find their results in some obscure journal.
*The most accurate solenoid model starts with a helical sheath waveguide model, and goes from there, loading up with semi-theoretical and empirical correction factors to get an accurate result. See: http://hamwaves.com/antennas/inductance.html
Note also that, winding the coil in place, tightly, with the desired geometry, gives a slightly different result from scrunching a broader winding: the latter will be slightly larger diameter as the extra skew length is reduced.
Finally, mind what assumptions underlie the most common formulas.  A uniform current sheet is usually used, or something similar to that.  Real wires are not uniformly distributed over the winding area, nor are they perfectly transparent to magnetic fields.  This will give a large divergence from the assumed ideal case, as only a tiny fraction of that winding area is actually occupied by wires, that are tilted significantly as they go.
Also, one more point of interest: note that, for the "100% width" case, even if the radius of the helix were shrunk to zero (ignore collision with the core), the winding makes a one-turn loop along the path of the core.  This creates field lines perpendicular to the toroid plane (poloidal).  This exists whether you have a core or not, turns or not, and arises simply from the fact that the winding goes around a loop path.  It can be canceled out by doubling back on the winding (if you don't mind the added capacitance / transmission line effects), or starting with the wire tucked in along the core, then doubling back on that.  (Why cancel it out? External fields: this can be relevant for EMI purposes, or say for reducing coupling between RF coils.)
