The watts label is in watts.
If your toaster says you use 1000 watts that is the same as 1 kilowatt. If you toast bread nonstop for one hour, that is 1 kilowatt-hour. If you toast bread nonstop for two hours, that is 2 kilowatt-hours.
Volts times amps equals watts. If the label only says watts and volts, you can divide watts by volts to get amps. If you live in America where the voltage is 120 volts the toaster uses about 8.3 amps.
These are called nominal ratings. These numbers are basically average numbers, and are good enough for most purposes, like estimating your electricity bill, or how many things you can plug into a circuit. If you actually measure the amperage, you might notice that, for example, the toaster might take 15 amps* for a few seconds while it heats up, because heating elements have less resistance when they are cold.
* (I'm not sure if this number is actually realistic)
So, what is 100W on a device label, is it 100W per hour or 100W per second?100 W means 100 joules per second....watts per second or watts per hour doesn't make any sense. It is like asking at what speed per hour you drove a car....you either ask what is the distance per hour or ask what is the speed.... – Mitu Raj Jun 24 '22 at 11:50
