I'm looking for a latching relay (so I can control its state remotely) with a manual switch (preferably with a rocker style switch, so I can control its state locally).
Do these exist as I'm struggling to find one?
Thanks
Thanks
If you can't find one, consider the option of having a local switch. Wire it in like you would the light-switches at the top and bottom of a staircase. Whatever the state of the switch at the bottom of the stairs, the switch at the top can always activate and deactivate the light.
Now,.... who knows how to convert it to a local with two remotes?
I looked for something like this a while ago. Doing a quick search, look at things like the HFE10-2
also keep in mind that depending on the type of switching you are doing, it doesn't take a lot to create a local trigger that delivers the same switching current to the relay with just a local spst button
The closest I can think of is the "NVR Switch" built around a relay, commonly used in machine tools. One green button to start it (energise the relay, which then drives the load and holds itself on) and a big red button to stop (breaking the relay coil circuit).
It's normal to take at least the "STOP" switch connections to remote locations, to allow emergency stop switches in obvious places.
It's deliberately NOT a latching relay so that it also switches off when power fails - the last thing you want is for unattended machines to restart when the lights go back on!
