I am looking to use a CT based SCR switch to switch an AC contactor. The switch specs list the following:
Off state voltage: 240 VAC RMS max. Minimum holding current: 10 mA. On state current: 1.0 AAC RMS max. continuous Off state leakage: 50 ua @ 240 VAC max. Peak Non-Repetitive Surge Current: 8 AAC RMS (1 cycle, 60 Hz.)
Does the "minimum holding current" refer to current passing through the CT or the SCR?
Full device specs are at. https://media.digikey.com/pdf/Data%20Sheets/CR%20Magnetics%20Inc%20PDFs/CR9300%20Series.pdf
