Here is my attempt:
Can someone explain to me how to proceed? How do I deal with the negative sign here? If I get the resonant frequency now, it will be complex.
Am I not supposed to use the negative sign for the capacitive reactance?
Here is my attempt:
    Their reactances are equal magnitude but opposing sign: -
$$j\omega L = -\dfrac{1}{j\omega C}$$
The minus sign allows us to mathematically equate them as equal reactances: -
$$j^2\omega^2 = -\dfrac{1}{LC}$$
And, because \$j^2 = -1\$: -
$$\omega^2 = \dfrac{1}{LC}$$
    Using the Laplace representation for R, L and C: $$\small R\rightarrow R ;\:\: C\rightarrow \frac{1}{sC}\:;\: L\rightarrow sL$$
First derive a Laplace transfer function (TF) where the output signal is across R//C.
Output impedance is R in parallel with L, $$z_o(s)\small=\frac{R/sC}{R+1/sC}=\frac{R}{1+RCs}$$
Input impedance is \$\small sL\$ in series with \$ z_o(s)\$,
Thus,
$$ z_i(s)\small=sL+\frac{R}{1+RCs}=\frac{RCLs^2 +sL+R}{1+RCs}$$
The transfer function is then, $$\frac{z_o(s)}{z_i(s)}\small=\frac{R}{RCLs^2 +sL+R}= \frac{1/LC}{s^2 +s/RC+1/LC}$$
By inspection, the natural frequency is, $$\omega_n \small=\frac{1}{\sqrt{LC}}=\frac{1}{\sqrt{5\times10^{-6}}}=447.21 \:rad/sec$$
and the damping coefficient is, $$\zeta=\small\frac{1}{2R}\sqrt{\frac{L}{C}}=0.11 $$
Finally, the resonant frequency (or 'damped natural frequency') is then, $$\omega_r =\omega_n \small\sqrt{1-2\zeta ^2} = 441.59\: rad/sec$$
