I am designing a custom board with a ATmega16u2. In the specifications of the linear voltage regulator, a 10uF capacitor is required between the regulated voltage and ground. A 1uF is required between the power and ground for the ATmega16u2, and a 100nF is required between the BMP388 power and ground. Do I use the highest value capacitor, or do I use all 3 capacitors in the circuit.
JYelton
  • 34,119
  • 33
  • 145
  • 265
  • Which regulator? And how are the devices connected? What types of caps being used? The answer will also depend on how far apart the devices are on a PCB. – Justme May 05 '22 at 10:10
  • Also related/useful: https://electronics.stackexchange.com/q/400683/2028 – JYelton May 05 '22 at 20:10
