I have a small circuit with a battery and a lamp. If I close the circuit the lamp will turn on, otherwise will turn off.
Example
I want to create a very small wireless switch. It will have only 2 signals to understand:
  • Turn On (close the circuit)
  • Turn Off (open the circuit)
The circuit will work with a 3V battery. And it need to be as small as possible. So, I think the Bluetooth will be the best. There are other good technology?
What I want is a start point. Where can I find a good book/tutorial to start this project? Or, if this is easy to say, how I build this switch?
Rodrigo
  • 219
  • 17
  • I would like to do almost the same thing and I would like to know if you succeed it and how ? I have done a small circuit and I would like to do three things: -Link to the right of the circuit OR -Link to the left of the circuit OR -Link to the ground So I need to build a bluetooth with a three way switch. –  Jan 08 '15 at 10:47
  • Hi @KevinBeauchamps, yes, I did it. This question was in the very fist phase of my project. And with the good answer from Gustavo Litovsky, a new world open for me. The answer is... ARDUINO. There are a lot of devices for arduino that use Bluetooh. One smaller that I found was here: https://tiny-circuits.com/ There are other models, but arduino is the answer. Search what you like more. Have fun. – Rodrigo Jan 08 '15 at 14:52
For BLE there are two popular devices:
CC2540 from TI
nRF8001 from Nordic Semiconductor
Both use BLE. You can then connect a relay to them to enable a switch. They have development platforms you can buy rather inexpensively and use (look at the key fob).
Gustavo Litovsky
  • 7,669
  • 26
  • 44
  • Great, this is a start point. It look like a small computer and I can configure a lot of things.. – Rodrigo Mar 21 '13 at 15:18
Do you have any experience with microcontrollers? To my knowledge (someone please correct me) BT modules have a serial data interface and require mode and configuration changes via said interface. You can't just hook up a couple of switches to it.
I'd suggest spending some time with a microcontroller devkit, one that has wireless options. You could do it over Wi-Fi with OpenPicus (sorry, no link, I'm on my phone). Google for wireless microcontroller development board and get familiar with it. That should get you started.
Outsider
  • 136
